Broken halfshaft experiences?
sims76
This was the last time that I will ever break an side axle or side axle U joint in my car...
making some changes over the winter I think this will solve the problem
fills the wheel well alittle better too...
probblaly already said, but ill add some info...
lets see...ive broken about 4 pairs of halfshafts in my car...thats right....8 ujoints let go...
some at 40mph, some at 0 doing burnouts....
the 40mph ones bent up the lower control arms a little bit, but nothing that id worry about....just the inner lip where the rear sway bar bolts too...but its a loud, MASSIVE clunking noise....
never had one let go at highway speed....
funny thing is, some were old shafts, two were rebuilt with Spicer joints....
the ones i have now are rebuilt with new grease everywhere and Percision ujoints....
I have found the original oem ujoints lasted the longest. the "hollow" greaseable ones seamed to be the weakest.
yeah, percision makes a non-hollow one that is still greasable...the nipple is inside one of the end caps with the needle bearings....
they are a little more expensive, but they are better...they end in P/N G...
i think 187s are Z car ones, im not 100% sure...and the "nice stronger ones" are 187G with the greaseable end caps..
Nice solution!!!!
