blochparty Posted August 7, 2006 Share Posted August 7, 2006 The oil pump on my '75 L28 motor gave up on the freeway and the motor seized completely. I haven't dropped the oil pan yet, but I did pull the valve cover and the cam journals (?) are mangled, cracked, etc., so I have a feeling it's pretty tatered--it obviously got pretty hot. I can't see any cracks in the block, but you know how that goes. Assuming there are no cracks in the block, can something this mangled be bored out & rebuilt? Or should I just haul it to the dump? I've listed it on craiglist a couple times to no avail... I just finished my sbc swap, so now I'm trying to clear out the garage. Quote Link to comment Share on other sites More sharing options...
johnc Posted August 7, 2006 Share Posted August 7, 2006 Without taking it a part you'll never know if it can be rebuilt. Is it worth spending the time and money to disassemble it? IMHO, no, if its a stock engine. Quote Link to comment Share on other sites More sharing options...
blochparty Posted August 7, 2006 Author Share Posted August 7, 2006 Thanks John! I'll take it apart and see what's inside; at least so I can get it onto my utility trailer to take to the dump. It was stock, had 200K miles, the fuel injection was shot, etc., etc., etc. Quote Link to comment Share on other sites More sharing options...
Clifton Posted August 8, 2006 Share Posted August 8, 2006 Also check the main caps. They should be snug when you pull them out. If they are loose from getting it hot down there, it's junk. Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted August 17, 2006 Share Posted August 17, 2006 i would consider finding a new(er) motor from a local junkyard becuase it sounds like your head is probally toast Quote Link to comment Share on other sites More sharing options...
