Install Pallnet Fuel Rail
darkzebra
I have tried many different sealants before coming to the conclusion that JB Weld is the best for the job. It works awesome for sealing the threads and you can remove the fittings later on with no issues. Once the fittings are installed with the JB Weld leave em sit and do not move them, the seal will be made. There is a carmaker out there that uses the same substance for sealing just as I do so, it's not uncommon.
