tybaldo Posted September 11, 2006 Share Posted September 11, 2006 how much boost does the stock turbo allow you to boost?and what pcm should i use to add more fuel to compensate the more boost? Quote Link to comment Share on other sites More sharing options...
flames_187 Posted September 11, 2006 Share Posted September 11, 2006 from what i been reading it depends on your setup...if all stock with a boost controller of some sort i couldnt imagine seeing anymore than 10psi w/o knock...now if u have some additions (intercooler,custom dp, ect) i could see a reliable 12-15psi...but guys on this forum can prove me wrong with the numbers they make... Quote Link to comment Share on other sites More sharing options...
tybaldo Posted September 12, 2006 Author Share Posted September 12, 2006 i already put a fp regulator, ford probe intercooler,and a homemade boost controller, but i still dont feel any difference on the car performance. what else would you suggest me to do? im running a stock turbo and a stock rebuild engine Quote Link to comment Share on other sites More sharing options...
Gollum Posted September 12, 2006 Share Posted September 12, 2006 If you've done all that you should definately be feeling a difference over stock. It sounds like something is wrong to me. I'm sure others here would have a better idea though, so let them chime in before freaking out. Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted September 12, 2006 Share Posted September 12, 2006 So how much boost are you running? 10psi will feel a little better, but you're only getting about 20hp over stock (Maybe 200whp) - 15psi is about where that turbo wakes up. With an intercooler, and some more fuel, IE secondary injectors, or a Z31 ecu upgrade and tuning. You can easily see 250+whp. I was making 267whp/324rwtq on a junkyard setup. 16psi, 2 secondary injectors, SDS EIC, EVO FMIC, 3" Exhaust (stock downpipe). It was very stout. I was also known to raise the fuel pressure on those two injectors and run over 20psi on the stock motor/turbo I've decided to upgrade the ECU to the Z31 setup, and bigger turbo. Hoping for 350rwhp. We should see this weekend. Quote Link to comment Share on other sites More sharing options...
nismopick Posted September 12, 2006 Share Posted September 12, 2006 I've decided to upgrade the ECU to the Z31 setup' date=' and bigger turbo. Hoping for 350rwhp. We should see this weekend.[/quote'] Good call. I couldn't believe the difference when I swapped to the Z31 ECU. Quote Link to comment Share on other sites More sharing options...
flames_187 Posted September 12, 2006 Share Posted September 12, 2006 maybe theres something wrong with your boost controller? Quote Link to comment Share on other sites More sharing options...
tybaldo Posted September 13, 2006 Author Share Posted September 13, 2006 i think i'll try upgrading to a z31 ecu then i'll let u know if there was a difference Quote Link to comment Share on other sites More sharing options...
tybaldo Posted September 14, 2006 Author Share Posted September 14, 2006 where did you install the secondary injectors? this is the firts time i ever ear about that Quote Link to comment Share on other sites More sharing options...
BleachZee Posted September 14, 2006 Share Posted September 14, 2006 My Z runs strong at 6psi. I can tell a big difference from 6 to 9 psi. (no intercooler) Quote Link to comment Share on other sites More sharing options...
