LamboZ Posted September 14, 2006 Share Posted September 14, 2006 Ive been searching and searching but I cant find it anywhere! Im pretty sure it was on this website, Im looking for a picture and the thread about how you can move you steering linkage rod using a hem joint and etc so you can clear your header/downpipe. im looking to do something like this, and any help/info would be great! Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted September 14, 2006 Share Posted September 14, 2006 http://www.borgeson.com/products.htm I also noticed MikeKZ put in an extra u joint. Might try contacting him. A couple of other guys said speed shops and/or tractor supply companies carry steering shaft U joints. summit carries steering joints and support bearings Shouldn't be hard to figure out how to do it once you have the hardware. Just make sure you solid mount the support bearing. Look at the tech info on the borgenson site. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 15, 2006 Share Posted September 15, 2006 As Pop said, you need another U joint. The heim joint just supports the steering shaft in a race car (like the steering column does in ours), but it doesn't allow it to pivot, so that is not what you need. Here's a link to the race stuff with heims: http://www.stockcarproducts.com/steer5.htm Quote Link to comment Share on other sites More sharing options...
heavy85 Posted September 15, 2006 Share Posted September 15, 2006 The '02 Camaro I'm parting out has the factory set-up with an intermetiate steering shaft with no support what so ever. Steering column / u-joint / intermediate shaft (just hanging in the air) / u-joint / steering rack. Obviously I was a little surprised when I saw this. Cameron Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted September 15, 2006 Share Posted September 15, 2006 Here are a couple of pics: Quote Link to comment Share on other sites More sharing options...
