badjuju Posted October 3, 2006 Share Posted October 3, 2006 K, so I made a nono on my 280, and just poked a hole in my upper rad hose, siliconed it and called it good. It worked for about 2 months, then I was toying with an old neon with all the extras (body kits, etc) and I suddenly realized I was going to get my ass stomped by the mondo turbo in this guy's car. I heard the loudest blowoff valve that has possibly ever been put into something which runs on gas. Well, no, it turns out it was my cooling system rejecting my clt mounting idea, and antifreeze flew all over my nicely powdercoated intake parts, which are now not so nicely powdercoated. At any rate, My stock clt i can't seem to get to work with msnse, and I don't know how to mount a GM clt other than putting a hole in my rad. What do others do? Quote Link to comment Share on other sites More sharing options...
Thumper Posted October 3, 2006 Share Posted October 3, 2006 Drill and retap your thermostat housing for the gm clt sensor. I forget the thread pitch but you should be able to search on hybridz or anywhere on the net for the size and pitch. Or just buy one and find a nut that fits it. Good luck. Quote Link to comment Share on other sites More sharing options...
badjuju Posted October 4, 2006 Author Share Posted October 4, 2006 thanks man, the only way to go i suppose. nice avatar by the way, i'm being V for halloween. Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted October 4, 2006 Share Posted October 4, 2006 I tapped out the thermostat housing, too. It is a 3/8" NPT. Ace is the only place I could find that carried the tap. Beware because tapping tappered threads into aluminum is really difficult. I cracked a thermostat housing the first time I tried it and had to buy a new one. Take your time. Quote Link to comment Share on other sites More sharing options...
badjuju Posted October 4, 2006 Author Share Posted October 4, 2006 My neighbor restors jenson interceptors, has a whole machine shop in his garage, I'll see if he'll help me out with it. Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 8, 2006 Share Posted October 8, 2006 There is a NICE adapter from the lower radiator hose of a 240SX that slips into the raidator hose, and contains a switch for the cooling fan. Unscrew the switch, install your CLT, or the CLT for a GM, and no tricky on-car machining is required! I found this recently, and thought "Oh, that's a trick switch adapter" usually they are in the radiator tank, but having one in the radiator hose makes for a nice universal mounting for just about anything! I believe the car was a 91 if memory serves. Summit makes several adapters like this as well. Hope this helps with giving you another option. Quote Link to comment Share on other sites More sharing options...
Alex_V Posted October 14, 2006 Share Posted October 14, 2006 You can grab it from the 89-94 240's for sure, and possibly the 95-98's. If you could get it from the latter cars then every 240sx will have them. ~Alex Quote Link to comment Share on other sites More sharing options...
Mack Posted October 18, 2006 Share Posted October 18, 2006 I just use the stock cylinder head temp sensor. use easy therm to configure MS&SE for it. although its not that far off from the GM unit. Quote Link to comment Share on other sites More sharing options...
seth Posted October 19, 2006 Share Posted October 19, 2006 Mack said: I just use the stock cylinder head temp sensor. use easy therm to configure MS&SE for it. although its not that far off from the GM unit. I did the same Quote Link to comment Share on other sites More sharing options...
twoeightythreez Posted November 26, 2006 Share Posted November 26, 2006 me too Quote Link to comment Share on other sites More sharing options...
