Guest Mark300zxTurbo Posted October 17, 2006 Share Posted October 17, 2006 what up, this is my first post. so I guess I gotta introduce myself. my name is Mark, I live in Yukon, Oklahoma. and I have a 1986 300zx Turbo. my engine is good, but I have a automatic transmission thats pretty messed up, it still drives fine, but I have no reverse, or overdrive. i'm pretty sure it needs a new torque converter and valve body also. so I think i'm gonna just swap my engine and tranny for a VG30DETT with 5 speed transmission. I found a set up for $1500. it includes: Motor (with turbos) Transmission (5sp) Uncut Wiring Harness All required Cables ECU Cam angle sensor (CAS) Complete Intake Manifold Alternator A/C (not gonna use) Power Steering Pump All Brackets and Sensors Shiftlinkage now what I need to know is if anyone has any information on what I need for this swap, and just what you think about it I guess. I also found a RB26DETT with tranny and everything for $3,000. but I don't know if its worth that much more. thanks. -Peace Quote Link to comment Share on other sites More sharing options...
flicktitty Posted October 17, 2006 Share Posted October 17, 2006 I'm 99% Sure the RB26DETT won't fit, i believe it has some problem withthe steering rack not clearing, i've only seen it done on RHD Z31's if you are serious about doing a swap i'd do a 2JZ. Or just keep with the VG30ET, it's just a underated motor. or ever think about a V8 Swap? Quote Link to comment Share on other sites More sharing options...
Dramier Posted October 23, 2006 Share Posted October 23, 2006 RB26 won't fit.. sorry bro. Steering column barely clears the 25, much less a 26. I have maybe a 1/2" clearance and I think Racin' has a 1/4" clearance with his, so that should give you an idea of how little room there is. IMO, you should either do an RB swap or do something completely different. Like I would love to see an AWD Z31.. maybe a Subaru motor/setup? If you're looking cheap, go V8. If you're looking easy, go factory motor. All else break out the wallet and the Tylenol. Quote Link to comment Share on other sites More sharing options...
Guest Mark300zxTurbo Posted October 24, 2006 Share Posted October 24, 2006 Subaru motor? that would be freaking weird! Quote Link to comment Share on other sites More sharing options...
b__sosick Posted October 25, 2006 Share Posted October 25, 2006 Subaru motor? that would be freaking AMAZING! quote fixed!! That's a killer deal I'd go ahead and buy that 1500 dollar set up. It will also be a little bit less of a head ache Quote Link to comment Share on other sites More sharing options...
Alex_V Posted October 25, 2006 Share Posted October 25, 2006 You could always buy it and part it out. And sell me the turbos cheap, I want to put them on my L28... ~Alex Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted October 25, 2006 Share Posted October 25, 2006 a vg30dett will not fit in a z31 without huge modifications, i have only seen one in a z31 and it was a non turbo motor. Build the vg30et, they have been proven time and time again to be good for over 400 hp, jason84na2t is making almost 500 ft/lbs. take a look at his site redz31.com Quote Link to comment Share on other sites More sharing options...
Clifton Posted October 31, 2006 Share Posted October 31, 2006 This RB26 fit. Your vg30 with a little more boost will make about as much power as the other 2 at there stock levels. I would only consider the vg30dett or rb26 if you want alot more power and are willing to spend the money ( larger turbo/turbos, fuel, ecu, ect) to make it happen. Quote Link to comment Share on other sites More sharing options...
flicktitty Posted October 31, 2006 Share Posted October 31, 2006 That Z31 is from Japan so the steering problem isn't a real problem (or so i've heard) so if you are really set on a RB26DETT then do a RHD conversion too. Quote Link to comment Share on other sites More sharing options...
djz Posted November 1, 2006 Share Posted November 1, 2006 This is from Z31.com, looks a bit tight. Quote Link to comment Share on other sites More sharing options...
240Zed Posted November 4, 2006 Share Posted November 4, 2006 Did anyone consider tilting the engine over to the opposite side to get some more room for the steering? plus maybe some modification to the steering? I reckon you could make one fit. Quote Link to comment Share on other sites More sharing options...
