coilovers and wilwoods
how come everyone forks out the good ideas AFTER i do it all? lol. i never even considered using a pipe cutter or angle iron...i guess im not the engineer i believed myself to be lol.
I thought i had read that people were using the softer rates in from and the stiffer rates in rear, i dont have a big V8 either, maybe that makes a difference what rates to use...
Different strokes for different folks. My car still felt like it understeered when I ran 200/250, I can only imagine the horrendous understeer I would have had with 325/250, but again, it's a cumulative effect of everything on the car, and your's could handle a lot different than mine with those spring rates.
Sometimes too soft will make it understeer. My rule of thumb, and I seem to be all thumbs :-), is that if you make two steps in the direction that should have a certain outcome (like less understeer) and you don't get your desired result then go the other way. I know this seems obvious but I've watched really smart people chase their tails as the keep going softer and softer and it works worse and worse.
Cary
In my case I started with 250/250 and that was bad, went to 200/250 and that was less bad. I hear what you're saying though. I added a thicker front swaybar to my Toyota P/U and the understeer decreased, presumably because the camber didn't change so much due to body roll. Then it decreased again when I added a rear bar.
If you were you'd still be analyzing all your options and trying to consider if the changes would be safe. Then you'd probably have used a metal lathe to cut the struts, applied a specific bevel to the strut tubes, created an overly elaborate jig to hold things, had then welded using a process known have ever heard of, etc.
Sometimes all you need are simple blacksmith skills
Cary
i thought i had welded the strut tubes together straight, but was a little off, so i tightened down the gland nut and gave the strut tube a whack and it centered itself! imagine that :wink:
an another note: they guys (and gals) over at techno toy tuning are making many suspention parts, normally just for the AE86 guys, but i checked them out and they have stuff for the Z cars. thier weld in camber plates go for $170/pair, cheaper than the AZC plates ($99/corner). i have neither so i cant comment on quality. I might pick up a set for my rears...
