rztmartini Posted October 26, 2006 Share Posted October 26, 2006 Am i sadly mistaken, or with the MSnS v. 3.0, i can just wire it up to my relay board like this and im good to go? Quote Link to comment Share on other sites More sharing options...
z-ya Posted October 27, 2006 Share Posted October 27, 2006 In theory, yes. If you do everything right the first time, it will just fire right up. But there is a fair amount of wiring, and most people are bound to make some mistakes. So plan on debug time. And also plan on dyno time. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 27, 2006 Share Posted October 27, 2006 rztmartini--Please use descriptive titles, I'm going to change this one. Take a look at the newly revised rules too: http://forums.hybridz.org/announcement.php?f=61&a=2 Quote Link to comment Share on other sites More sharing options...
rztmartini Posted October 28, 2006 Author Share Posted October 28, 2006 yes sorry about that...thank you for re-naming it. as far as using the GM HEI, will there need to be any changes to the board itself? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 30, 2006 Share Posted October 30, 2006 The drawing you see there assumes the board is configured for the Hall sensor / optical trigger input (if you bought a preassembled board from us, that's how we set them up by default) and that you have included the spark output through VB921 mod. With the GM HEI module output, it depends on which pin you are trying to trigger it from. Quote Link to comment Share on other sites More sharing options...
rztmartini Posted November 1, 2006 Author Share Posted November 1, 2006 so if i want to use the stock 83 zxt dizzy and the VB921 to fire ignition, what modifications to the board itself needs to be done? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 1, 2006 Share Posted November 1, 2006 We've got a complete write-up on what board mods you need on the article where that drawing came from: http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_280zx_turbo.htm If you bought it preassembled from us, it should have all the input mods already done, unless it was a special order. The input mods are removing C12 and C30, jumpering D1, and removing R57. These mods are all there for triggering off a coil terminal, and our usual preassmbled units are not built that way. Quote Link to comment Share on other sites More sharing options...
big-phil Posted November 30, 2006 Share Posted November 30, 2006 Matt Cramer said: We've got a complete write-up on what board mods you need on the article where that drawing came from: http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_280zx_turbo.htm If you bought it preassembled from us, it should have all the input mods already done, unless it was a special order. The input mods are removing C12 and C30, jumpering D1, and removing R57. These mods are all there for triggering off a coil terminal, and our usual preassmbled units are not built that way. So Matt I got a preassembled ms1 v 3.0 from you, the mod mentioned here has already been done? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 30, 2006 Share Posted November 30, 2006 The input mods will be already done. Our off the shelf unit will not have the jumpers for the direct coil control output mod, although we have built some special order units set up that way. If you did not special order it with the mod in place, here's how to add it: http://www.msextra.com/manuals/MS_Extra_Ignition_Hardware_Manual.htm#singlecoil Quote Link to comment Share on other sites More sharing options...
