MSnS v. 3.0 wiring question
rztmartini
In theory, yes. If you do everything right the first time, it will just fire right up. But there is a fair amount of wiring, and most people are bound to make some mistakes. So plan on debug time. And also plan on dyno time.
The drawing you see there assumes the board is configured for the Hall sensor / optical trigger input (if you bought a preassembled board from us, that's how we set them up by default) and that you have included the spark output through VB921 mod.
With the GM HEI module output, it depends on which pin you are trying to trigger it from.
We've got a complete write-up on what board mods you need on the article where that drawing came from:
http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_280zx_turbo.htm
If you bought it preassembled from us, it should have all the input mods already done, unless it was a special order. The input mods are removing C12 and C30, jumpering D1, and removing R57. These mods are all there for triggering off a coil terminal, and our usual preassmbled units are not built that way.
  • 4 weeks later...
So Matt I got a preassembled ms1 v 3.0 from you, the mod mentioned here has already been done?
The input mods will be already done. Our off the shelf unit will not have the jumpers for the direct coil control output mod, although we have built some special order units set up that way. If you did not special order it with the mod in place, here's how to add it:
http://www.msextra.com/manuals/MS_Extra_Ignition_Hardware_Manual.htm#singlecoil
