John Scott Posted October 31, 2006 Share Posted October 31, 2006 Are six bolt CVs, lets say from 86 non-turbo 300ZX, same as older 280 ZXT six bolt CVs? Probably answered in a post somewhere. Been digging for days and can't find answer. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 31, 2006 Share Posted October 31, 2006 Not the same. 300ZX NA isn't useful for any early Z swap. The shafts are too long and the flange is too wide. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted October 31, 2006 Share Posted October 31, 2006 Only difference is the length of the center axle shaft. As Jon mentioned, the 300ZX ones are longer. The sheet metal grease cover on the 300ZX CV axle has a smaller dimple than the 280ZX Turbo CV axle. This dimple houses the pre-load spring. The smaller dimple cover can be used on the 280ZX axles and this makes them easier to install on the earlier Z cars. Quote Link to comment Share on other sites More sharing options...
John Scott Posted November 1, 2006 Author Share Posted November 1, 2006 Since the 300ZXT shafts are a desirable swap into early Zs, How do the length of the 300ZXT shafts compare? I assume they are the same length as non turbo shafts, but greater range of compression? Quote Link to comment Share on other sites More sharing options...
briann510 Posted November 5, 2006 Share Posted November 5, 2006 Where can one get the sheet metal grease cover from the 300ZX CV axles? Dealer says no have andcant get, and not too many people will want to remove this plate to sell it if their axles are good. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted November 12, 2006 Share Posted November 12, 2006 Where can one get the sheet metal grease cover from the 300ZX CV axles? Dealer says no have andcant get, and not too many people will want to remove this plate to sell it if their axles are good. I got mine from The Z Barn off some bad (cores) Z31 axles. Quote Link to comment Share on other sites More sharing options...
briann510 Posted November 12, 2006 Share Posted November 12, 2006 I also found a perfectly flat plate with the 6 bolt hole pattern also in my searching. Now whether this is a custom plate someone made or a stock one I dont know. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted November 12, 2006 Share Posted November 12, 2006 I also found a perfectly flat plate with the 6 bolt hole pattern also in my searching. Now whether this is a custom plate someone made or a stock one I dont know. It's the stock Nissan part for the 720 4x4 truck CV axle. They're even harder to find than the Z plates. Quote Link to comment Share on other sites More sharing options...
