jimlickster Posted November 16, 2006 Share Posted November 16, 2006 My New Engine is Complete and Running VERY well. You guys helped me with it and i really appreciate it. I have recently found a Really Cool Hood Scoop that i can use with a Tunnel Ram and really would like to have that setup. The Problem is, If i put another Carb on my Engine, would it be too much Fuel? What would the Tunnel Ram and Extra Carb do to my Performance? I was thinking of running (2) 600 CFM Edelbrocks. The Engine: 350 4 Bolt Main .060 Over Cam: 218/218 at .050 (284/284 Advertized) .458 Lift 110 Lobe Separation Crank: NEW Std/Std Nodular Steel Counterweighted Rods: NEW 5.7" H-Beam Press Fit Pistons: Flat Top Hyper (10:1) Heads: Stock 882 76cc Chambers Standard size Valves (Will Upgrade to 64cc Aluminum Soon) Pushrods: Hardened Steel Valve Springs: .600 Lift Rated Rockers: 1.6:1 Rollers Is this Overkill? Will It Affect whether i use Pump Gas or Not? Quote Link to comment Share on other sites More sharing options...
jimlickster Posted November 16, 2006 Author Share Posted November 16, 2006 Here's a Pic of the Engine: Quote Link to comment Share on other sites More sharing options...
Bartman Posted November 16, 2006 Share Posted November 16, 2006 Is it overkill...probably. I think dual quad's is more of a style issue than strict performance (at least in most installations), if it's something you like I'm sure you can make it work. Two40MuscleZ is running a tunnel ram and someone else put a system on their car recently, but I don't remember who. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted November 16, 2006 Share Posted November 16, 2006 just some info tunnel ram intakes work most effectively on a 350 sbc in the 3500rpm-8500rpm plus band, AND REQUIRE MATCHING CAM TIMING AND COMPRESSION RATIOS, PLUS A REAR GEAR RATIO THAT ALLOWS THE ENGINE TO STAY IN THAT 3500rpm-8000 PLUS RPM BAND below that, mixture distribution, the large plenum and straight runners ram tunning tends to be counter productive, or not effective yeah it will look good ,but a good single plane intake like this http://store.summitracing.com/partdetail.asp?part=HLY%2D300%2D110&N=700+115&autoview=sku will usually produce better power up to about 6000rpm with far less tunning issues, general rule is youll need a 240 duration cam at .050 lift or larger and matching 10.5 or greater cpr and a minimum of 3.73 rear gears, with 4.56:1 -4.88:1 being a better match things to read http://victorylibrary.com/mopar/intake-tech-c.htm http://www.newcovenant.com/speedcrafter/calculators/intake.htm http://www.grapeaperacing.com/tech/inductionsystems.pdf http://www.hotrod.com/techarticles/carburetor_shootout/index.html Quote Link to comment Share on other sites More sharing options...
HICKL Posted November 16, 2006 Share Posted November 16, 2006 Hey Jim, first off, 600's are too much. I am running a dual quad tunnel on mine but have 2 Holley 450's. It does look cool and runs' great at wide open throttle but does take a while to get used to as it looses a ton or power/torque down low. If your motor isn't built to spin high r's you will not see the benifit of it or will blow your motor trying. My 1/4 mile times did drop with mine but it is a trade off for day to day use and expect double the tuning problems. You did not mention your drivetrain, but I would not put this in front of an auto tranny unless you have a huge stall and are doing strip only. I like mine but won't run it forever. Jeff Quote Link to comment Share on other sites More sharing options...
