Wide260z Posted November 19, 2006 Share Posted November 19, 2006 I had heard one on thread that you could do a z31 ecu upgrade. I have the MAF and the turbo ecu out of an 88 but i was wondering if i still needed the crank angle sensor out of the car as well, or if the factory 82 turbo CAS will work. Thanks, Kris~ Quote Link to comment Share on other sites More sharing options...
Alex_V Posted November 19, 2006 Share Posted November 19, 2006 yea im pretty sure you do. Look at the bottom of this page, its a pretty cool feature.... ~Alex Quote Link to comment Share on other sites More sharing options...
wreckedj30 Posted December 5, 2006 Share Posted December 5, 2006 what up i ust did this swap and it definetly helped out. There seems to be a couple different versions of it though. I used the early 3z ecu, 84-86, that way i didn't have to mod much, if you use the later modles 87+ its more upgradeable. But i don't no how to do that one. And yes 82-83 is the only distrib. that'll work. Goodluck:mrgreen: Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted December 6, 2006 Share Posted December 6, 2006 will this work on a na car? Quote Link to comment Share on other sites More sharing options...
wreckedj30 Posted December 6, 2006 Share Posted December 6, 2006 i don't believe so, because the z31 ecu controls the turbo and what not. The swap also removes the detonation sensor. I'll ask the big homie, and get back to you. Quote Link to comment Share on other sites More sharing options...
wreckedj30 Posted December 6, 2006 Share Posted December 6, 2006 ok, you can use it on the n/a, but you have to cut the ecu plugs, and solder in the ecu plugs from the z31. The 280zx n/a plugs are way different from the z31 and s130t. You also have to use the s130 turbo distributor and run all the wire to the z31 ecu. Hope that makes since. Its not to easy. Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 6, 2006 Share Posted December 6, 2006 Hopefully everyone knows about the huge sticky "HOW TO" thread about the Z31 ecu swap????? It's been around here for a long time: http://forums.hybridz.org/showthread.php?t=91250 That thread explains most everything. Anyway... it's deffinately worth it on the 280zxt if you're on a budget. I did my swap this last summer & also did WreckedJ30's this last weekend. My total for the swap was $30... that's why I did it. If you bought all the parts from the junk yard / ebay: -$30 to $80 for the Z31T ecu (use the 84-86T ecu) -$10 to $30 for the Z31 MAF -$0 to $10 for the distributor chopper wheel -$0 to $10 for the ecu plugs & a couple inches of attached wires. Quote Link to comment Share on other sites More sharing options...
wreckedj30 Posted December 6, 2006 Share Posted December 6, 2006 he's luck i paid almost 200 for all the parts, and that includes getting jacked by nismo619, so if anyone see's him bring it up and complain. Quote Link to comment Share on other sites More sharing options...
Guest vegas datsun Posted December 6, 2006 Share Posted December 6, 2006 what are the benifits of the conversion? what does it help or do for you? Quote Link to comment Share on other sites More sharing options...
Mack Posted December 6, 2006 Share Posted December 6, 2006 go megasquirt, much better and only marginally more expensive. Quote Link to comment Share on other sites More sharing options...
wreckedj30 Posted December 7, 2006 Share Posted December 7, 2006 i would of gone megasquirt, but didn't really have any money to do it, you could always buy one for me, Mack..lol. Hmm, benifits, well my car kept dying, and it fixed that, it controls your fuel and detonation sensor inside the ecu. It feels much better throttle wise, and is a lot cleaner setup. It elimates the stock bulky afm. If anyone can think of anything else bring it up, nismo knows. Plus you can also elimate the vacuum crap underneath the stock afm. Quote Link to comment Share on other sites More sharing options...
Kash Posted December 13, 2006 Share Posted December 13, 2006 You do not need the chopper wheel from the Z31 distributer (optional). Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 13, 2006 Share Posted December 13, 2006 You do not need the chopper wheel from the Z31 distributer (optional). Oh really... how is it "optional" ??? Quote Link to comment Share on other sites More sharing options...
Kash Posted December 13, 2006 Share Posted December 13, 2006 ??? optional...the 280zxt chopper wheel works just fine. Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 13, 2006 Share Posted December 13, 2006 ??? optional...the 280zxt chopper wheel works just fine. And you've had "personal experience" proving that? Interesting... because the holes are different & they don't give the same signal to the ecu... Quote Link to comment Share on other sites More sharing options...
Kash Posted December 15, 2006 Share Posted December 15, 2006 One of the four inner holes on the z31 wheel is about twice the size of the matching hole on the s30 wheel but they both work just fine, my car felt no different after i finally made the switch. Quote Link to comment Share on other sites More sharing options...
