cpt jack Posted December 3, 2006 Share Posted December 3, 2006 I saw this R32 GT-R LSD for sale 200$ shiped... i have a 83 280zx and i was wondering if i could put that in my diff thats in the car now.... Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 3, 2006 Share Posted December 3, 2006 It all depends on what the GT-R diff is.... is it a CLSD or a VLSD? a long nose or a short nose.... Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 3, 2006 Share Posted December 3, 2006 Believe it is short nose. You should search. It has been covered alot. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 3, 2006 Share Posted December 3, 2006 Do you mind sharing where its at? I's like to see what it looks like... Quote Link to comment Share on other sites More sharing options...
NZeder Posted December 4, 2006 Share Posted December 4, 2006 I believe some of the R32 GT-R have CLSD (not a GTR guy but I know of someone else who used one of these as it was a CLSD center) they are shortnose also not sure if the ring gear is 12mm or the odd ball 13mm. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 4, 2006 Share Posted December 4, 2006 They use a Tomei CLSD carrier which has steeper ramps then then the USA Z31T carrier. It might be worth looking into. Alas I ordered a powerbrute for low money and for me it is better just to go new. EDIT: I searched some here and apparently the splines on this (GTR) diff are too numerous or the shaft is too large a diameter. The 300zx TT shafts apparently work though. It is 12mm bolt. Quote Link to comment Share on other sites More sharing options...
cpt jack Posted December 5, 2006 Author Share Posted December 5, 2006 I want a lsd in my car bad! lol... where do u guys recomend to get one? like a shop online anywhere? Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 5, 2006 Share Posted December 5, 2006 I want a lsd in my car bad! lol... where do u guys recomend to get one? like a shop online anywhere? LSD thread under term "Powerbrute" in group buy. About $450-500 Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 6, 2006 Share Posted December 6, 2006 They use a Tomei CLSD carrier which has steeper ramps then then the USA Z31T carrier. It might be worth looking into. Alas I ordered a powerbrute for low money and for me it is better just to go new. EDIT: I searched some here and apparently the splines on this (GTR) diff are too numerous or the shaft is too large a diameter. The 300zx TT shafts apparently work though. It is 12mm bolt. Are you ABSOLUTELY SURE of this info? It seems to contradict our previous findings. As far as we know now the Z31 carrier has a big spacer and not as many clutches and steeper (not as aggressive) ramps. The Power Brute apparently is the same as the Nismo carrier, and it has the more aggressive ramps, more clutches and uses the same spline count as the Z31. The VLSD that came in the 88 SS apparently came with larger stub shafts and a higher spline count than the regular CLSD side gears. The S15 HLSD also uses a larger shaft. I think to this point those are the only two we've identified that use a larger stub shaft. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 6, 2006 Share Posted December 6, 2006 I mean this diff has harder lock up than the Z31T. Not steeper ramps, sorry. I am 90+% sure and about 75+% sure that the axles are larger. I remember reading it somewhere on here very recently and then I checked an R32 GT-R diff ad on Ebay which stated similar things. I will look harder. I definately saw pictures of less angled ramps though aswell as a different shaped carrier then the standard Z31T. Quote Link to comment Share on other sites More sharing options...
