tfreer85 Posted February 9, 2007 Share Posted February 9, 2007 Can someone please explain to me what "bwt5" means. Borg Warner T-5. Borg Warner 5 spd Transmission. Tyson Quote Link to comment Share on other sites More sharing options...
jernut Posted February 10, 2007 Author Share Posted February 10, 2007 Borg Warner T-5. Borg Warner 5 spd Transmission. Tyson thanks for the info! Quote Link to comment Share on other sites More sharing options...
73ZCAR Posted February 13, 2007 Share Posted February 13, 2007 Jernut, Depending on who made the cam, sometimes you can find info stamped on the firewall end of the cam. Nissan used letter codes, A, B, C, etc... Crane actually uses the stock # of the cam, something like 068-1014 and such. If you are in there for valve lash adj. or whatnot just use a little mirror and have a look. Mike. Quote Link to comment Share on other sites More sharing options...
jernut Posted February 13, 2007 Author Share Posted February 13, 2007 Jernut, Depending on who made the cam, sometimes you can find info stamped on the firewall end of the cam. Nissan used letter codes, A, B, C, etc... Crane actually uses the stock # of the cam, something like 068-1014 and such. If you are in there for valve lash adj. or whatnot just use a little mirror and have a look. Mike. This might be a better option. When I bought the car there was a evry loud tick. It has gotten better since then, but I think it need the valve lash adjusted. I will have to do some research first. I have never tried to do that before. I am slowly learning more and more. Quote Link to comment Share on other sites More sharing options...
jernut Posted March 11, 2008 Author Share Posted March 11, 2008 Just a follow up of the question of the 0-60 times. I took the 240z to the track last summer and ran a 15.4 at 89mph. since then I have done a tune up and changed the timing to 36 degrees total advance. It pulls really hard up top now. I have to look into a new differential to go with the 5 speed. Quote Link to comment Share on other sites More sharing options...
