nbesheer Posted February 23, 2007 Share Posted February 23, 2007 I have this fan thing stuf to the side of my engine that i guess blows air over the intake manifold(?) but it doesn't run at Ide/1k/2k/3k/4k RPM so i don't think it even works so should I see about replacing it or just removing it because I see people on here with out it. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted February 23, 2007 Share Posted February 23, 2007 Can you post a pic? Quote Link to comment Share on other sites More sharing options...
bschiltz Posted February 23, 2007 Share Posted February 23, 2007 It's the line warmer. It never seemed like mine worked either, but I think it just blows really softly. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted February 23, 2007 Share Posted February 23, 2007 Practice your three pointer with it..aiming at the garbage bin. Quote Link to comment Share on other sites More sharing options...
TimZ Posted February 23, 2007 Share Posted February 23, 2007 It's the line warmer. It never seemed like mine worked either, but I think it just blows really softly. No - it's for cooling the fuel lines after shutdown to prevent vapor lock in hot weather. Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted February 23, 2007 Share Posted February 23, 2007 No - it's for cooling the fuel lines after shutdown to prevent vapor lock in hot weather. Thats 100% right. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted February 23, 2007 Author Share Posted February 23, 2007 Mike it is the Y shaped thing in the middle of the valve cover. http://dcerutti.smugmug.com/photos/87164462-M.jpg So after running my car for a bit I should turn it off and check to see if it is blowing air and if it is not is it safe to remove it ? I run a lol bone stock NA, well with a CAI so go ahead and make fun of me for that haha. if that sways the descision at all. And I am in Southern California too. Quote Link to comment Share on other sites More sharing options...
X64v Posted February 23, 2007 Share Posted February 23, 2007 If memory serves me correctly, it only comes on at a certain coolant temp...something like 210 or so. You can totally ditch it though. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted February 23, 2007 Share Posted February 23, 2007 Mike it is the Y shaped thing in the middle of the valve cover.http://dcerutti.smugmug.com/photos/87164462-M.jpg Hmm... no idea what that is:shock:... better leave it to the L6 guys:mrgreen: Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted February 23, 2007 Share Posted February 23, 2007 its also called the "injector fan" just chuck it...you dont need it... Quote Link to comment Share on other sites More sharing options...
nbesheer Posted February 23, 2007 Author Share Posted February 23, 2007 Well I think I am going to take it off, but still keep it. i've kept everything i replaced worth replacing might as well keep this too. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted February 23, 2007 Share Posted February 23, 2007 It's the Auxiliary cooling fan on 280ZX's. When you shut the car off it will come on and run for about 15 min. if your engine coolant temp. is over 221 F. It wiil shut off if you turn the ignition switch on or start the car before that. It blows air over the injectors and fuel lines to cool the fuel temps. This is to aid in starting a car in hot weather or hot engine temps. I would not remove it. LARRY Quote Link to comment Share on other sites More sharing options...
gvincent Posted February 23, 2007 Share Posted February 23, 2007 I wouldn't be too quick to toss that injector/fuel rail cooler. I would keep it around if your going to beef up that L6. I have one of those fans in my 78 280Z and it definately did come on sitting in traffic during the summer with the AC on. This is in Boston MA with temps outside in the low to mid 90's. My 280Z has had a lot of head work done, a custom healthy cam grind, 6-1 headers and bigger injectors and throttle body. So keep it around, it may come in handy some day. Greg Quote Link to comment Share on other sites More sharing options...
