Question about LT1 accelerator cable.
I used the stock cable and modified the end to connect to my 240Z accelerator pedal. I did have to modify the length and I wound up connecting it using bicycle brake parts (the throttle cable is similar to a bicycle brake cable).
Interesting, I'll take a look at that.
I took the F-body gas pedal and cut the cable end off and welded it to the stock 280Z pedal. Then I used the stock f-body cable. It bows up slightly, but fits just fine.
Jody
This might be the easiest way. I just picked up some of those cable clamp things. I need to make a adapter plate for the firewall, the hole is too big for the Z28 grommet. I'll give it a test tonight.
