jonus079 Posted March 9, 2007 Share Posted March 9, 2007 today i decided to test fit the engine even though i dont have the transmission yet. i really just wanted to see if the intake would clear the hood. well intake will not fit. a big problem is the rear part of the intake hits the latch so i cant move the engine all the way back. it also would certainly hit the steering rack. i def need to move the engine back more for the turbo also. its a big turbo that i want to mount in the front of the engine comparments, theres no way it will fit with the engine as close to the front as it is now. so i guess im gunna use an ls1 intake....although i really didnt want to....oh well. sorry if the pictures are too big btw i dont plan on using that big ugly fan, just was to lazy to take it off. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted March 9, 2007 Share Posted March 9, 2007 Is that a baby LS1? Mario Quote Link to comment Share on other sites More sharing options...
jonus079 Posted March 9, 2007 Author Share Posted March 9, 2007 5.3l lm7...or yeah i guess you could call it the baby ls1:) Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted March 9, 2007 Share Posted March 9, 2007 Get a LS1 or 6 manifold or buy a custom low profile sheetmetal one especially since by the size of that turbo you're runnning BIG boost. I wouldn't take the chance on a stock 5.3L plastic intake. Best of luck finding the solution, Tyson Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted March 9, 2007 Share Posted March 9, 2007 cut the latch off. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted March 9, 2007 Share Posted March 9, 2007 cut the latch off. What he said... hood pins are your friend Quote Link to comment Share on other sites More sharing options...
jonus079 Posted March 9, 2007 Author Share Posted March 9, 2007 cut the latch off. i was thinking about that but i would still need to modify the hood to get it to fit. id rather not put a hood scoop in. i am still considering it though. Quote Link to comment Share on other sites More sharing options...
Savage42 Posted March 9, 2007 Share Posted March 9, 2007 If you cut the latch, it should let the motor sit back, then getting the block to clear the crossmember and then go with an underdrive pulley, you may get pretty close to where you need to be. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 9, 2007 Share Posted March 9, 2007 You have that motor about 6 inches farther forward than it needs to be. I am running a carb's intake, but have the front of my pulley sits right over the middle of my steering rack. You don't have to eliminate the hood latch. Just move it over 5 or 6 inches. Common mod. That is what I am going to do to allow a 14 inch air cleaner. Look at Pete Paraska's alteredz.com site to see how he did it. You can also put up to 1/2 inch spacers between the crossmember and frame rails (i.e. JTR spacers) to gain some more hood clearance. Moving the engine back should help with the hood clearance issues. The Z hood slopes pretty good so farther back is better. Where is your alternator going to be? Quote Link to comment Share on other sites More sharing options...
bschiltz Posted March 9, 2007 Share Posted March 9, 2007 Holy turbos, Batman! That thing is a monster! Quote Link to comment Share on other sites More sharing options...
jonus079 Posted March 9, 2007 Author Share Posted March 9, 2007 i went ahead and drilled the spot weld and removed the latch.. AND IT FITS! really close though...i did put the engine kind of high up for a safety space but it fits. the hood i have helps out alot, its like it was made to fit around that intake! its kinda dark now but ill make sure to take some pictures tomarrow before i pull the engine out again. thanks for all the help guys, i would have gave up without it! Quote Link to comment Share on other sites More sharing options...
jonus079 Posted March 9, 2007 Author Share Posted March 9, 2007 You have that motor about 6 inches farther forward than it needs to be. I am running a carb's intake, but have the front of my pulley sits right over the middle of my steering rack. You don't have to eliminate the hood latch. Just move it over 5 or 6 inches. Common mod. That is what I am going to do to allow a 14 inch air cleaner. Look at Pete Paraska's alteredz.com site to see how he did it. You can also put up to 1/2 inch spacers between the crossmember and frame rails (i.e. JTR spacers) to gain some more hood clearance. Moving the engine back should help with the hood clearance issues. The Z hood slopes pretty good so farther back is better. Where is your alternator going to be? btw i clicked the link and it didnt work. id really like to see that site. also i have the orignal alternator bracket for the engine so i think ill keep it in the stock location(although i dont like how it looks). i may use all the acc. from a z28 becuse then the belt will be closer to the engine. in need all the space i can get in front of the engine becuase of the turbo. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 10, 2007 Share Posted March 10, 2007 That is because I don't know how to spell. http://alteredz.com/ here is his hood latch. Quote Link to comment Share on other sites More sharing options...
jonus079 Posted March 10, 2007 Author Share Posted March 10, 2007 here are the new pictures. if they are to small you can click on the link in my sig to see the larger version. Quote Link to comment Share on other sites More sharing options...
