Power-Brute Install
trwebb26
I just purchased a power-brute LSD off of the group buy. I want to install it in the rear end along with a 3.9 set of gears, new bearings, and new seals. I'm mechanically inclined enough to do it, but I'm wondering if it would be worth the money to take it to a guy in town who sets up rear-ends for all of the local hot-rod guys. He'd have a LOT more experience - AND - all of the right tools for the job. I think I'm most worried about doing the job and missing something (backlash, teeth pattern, preload, etc) and having to rip it all apart again. Thoughts?
I also want to echo the thank you.
I now know how to remove and install the parts, and make the correct measurements. The last piece of information that I have not seen is torque specs. Does anyone have the torque specs for:
1. Bearing caps
2. 12 mm ring gear bolts
Additionally, I assume I should use some sort of Loctite on at least the ring gear bolts. Is this correct? What kind?
Again, thank you for all the help!
Joshua
