Darkone Posted April 17, 2007 Share Posted April 17, 2007 im doing a v8 swap in my 77 280 and the moter i am using is a Tune port injected 350 and a t5 trans but im having a problem finding a flywheel i think i need the 152 toothed one but cant figure out what vehicals these came in this is a car bellhousing so i guess i need the small flywheel any help would be apreciated. Quote Link to comment Share on other sites More sharing options...
jimszx Posted April 17, 2007 Share Posted April 17, 2007 I got mine from summit racing, made by scat for under $50 Quote Link to comment Share on other sites More sharing options...
2500lb Tuxedo Posted April 18, 2007 Share Posted April 18, 2007 i got my flywheel recently also but for a lt1/t5... it should be the same as for your motor i think.... im using a third gen camaro bell housing... tpi motor looks great i almost went that route cuz the engine looks so kool. check this out hope it helps. http://forums.hybridz.org/showthread.php?t=97577&highlight=lt1+bellhousing Quote Link to comment Share on other sites More sharing options...
Pyro Posted April 19, 2007 Share Posted April 19, 2007 It is a 153 tooth flywheel. A lot of cars came with that flywheel. Mid to late 80's camaro's and mid 60's nova's, for example. Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted April 19, 2007 Share Posted April 19, 2007 I would use a nodular iron flywheel - the weighed in around 14+ lbs. Check out the chart on this page http://cgi.ebay.com/ebaymotors/1986-Up-SB-Chev-Nodular-Iron-Lightweight-Flywheel-12-75_W0QQcmdZViewItemQQcategoryZ33732QQihZ019QQitemZ8030219432 for the right correct part number for your application. BTW, get the casting number off the engine and then use the chart at MorTec http://www.mortec.com/castnum.htm to figure out what engine you have. Quote Link to comment Share on other sites More sharing options...
lbhsbZ Posted April 19, 2007 Share Posted April 19, 2007 There's another guy on ebay that sells SFI rated steel flywheel for about $80. They weigh in at 18lbs IIRC. The stock flywheels are closer to 35lbs Quote Link to comment Share on other sites More sharing options...
pparaska Posted April 19, 2007 Share Posted April 19, 2007 This one: http://www.sdparts.com/product/14085720/1985EarlierSBCBBCNodularIronLightweightFlywheel1234in.aspx pointed out above, is only 15lb. Not SFI rated, but tested to 10,000 rpm. See my post about it in a related thread: http://forums.hybridz.org/showthread.php?t=97747 Wow, the one for the 86-up 1-pc seal engine is $309 at sdparts!!!!! The ebay price of $230 in that link speedracer gave is better, but, No thanks, I'd be looking for aftermarket for a light flywheel for the 1-pc seal engines! I run a scattershield (the new Sonic/Tilton one for 153 tooth flywheels): http://www.tiltonracing.com/content.php?page=feat1 so if it breaks, I am not too concerned. I have to have it resurfaced - there are a few heat spots on it that I need to have the speed shop/performance machine shop look at - I may be buying another one or an SFI rated aluminum one with a replaceable steel insert. Quote Link to comment Share on other sites More sharing options...
wheelman Posted April 20, 2007 Share Posted April 20, 2007 Watch out with the 86 and up Camaro flywheels, they are set up for external balancing just like the LT1. I know this for 100% sure, I have a 153 tooth 16lb flywheel from a 86-up 305 on my LT1. These engines all had 1 piece rear main seals and a different bolt pattern on the flywheel. The flywheel works perfectly with the LT1 and makes for an easy match to a T5 using the Camaro bellhousing, clutch fork and clutch parts. Wheelman Quote Link to comment Share on other sites More sharing options...
pparaska Posted April 20, 2007 Share Posted April 20, 2007 Maybe a quote from the Scoggin-Dickey site for the 86+ flywheel helps here: Technical Notes: Flywheels, in engines before 1986 us a two-piece rear seal. The bolt circle on pre-1986 production crankshafts is 3.58†in diameter. For 1986 and later production crankshafts the bolt circle is 3.00â€. If your engine has a crankshaft with a one-piece rear seal, you must use a flywheel (or flexplate) with a 3.00†bolt pattern and a counterweighted flywheel for proper engine balance. Quote Link to comment Share on other sites More sharing options...
Darkone Posted April 22, 2007 Author Share Posted April 22, 2007 Found the right flywheel at autozone Part#6527 for 59.99 + 145.00 core charge its the 153 type for a 86 camaro and weighs 15lbs Quote Link to comment Share on other sites More sharing options...
pparaska Posted April 22, 2007 Share Posted April 22, 2007 Cool. I found the 15lb "up through 1985" flywheel under part number 6515 for the same exact price (59.99 + 145.00 core charge). Mine is maybe not so hot looking and I may just take it in as a core and get a new one! http://autozone.com/R,APP1099301/vehicleId,1144203/initialAction,partProductDetail/store,2821/partType,00906/shopping/partProductDetail.htm Quote Link to comment Share on other sites More sharing options...
