240SX TB question
Zmanco
I've been enlarging the opening of the intake manifold. I'm noticing that there is no way to enlarge the intake opening to match the TB as I'll run out of material. Here's a picture - if you look inside you can see how much smaller the manifold's intake is compared to the TB. It's a little deceptive due to the distortion from the lense - I was only a few inches away.
http://album.hybridz.org/showphoto.php?photo=14470&cat=500&ppuser=16153
Is this normal? I'm guessing it is, but would rather check before I install it.
I agree, I have done dozens of these and NEVER had to 'weld in material'.
What manifold? I use primarily P82's and N42's--with the occasional turbo manifold (forget the casting number on it). All have been close on the bottom, but nowhere near cutting through.
Originally I wasn't using a spacer either. But then I converted it to the ball linkage and used a spacer, but the initial grinding was made for a straight bolt on to the manifold.
I made my own spacer as well, and it's as big as the tb bore. How big is this tb?
This was on an 82 ZXT turbo intake manifold.
Mario
