Speed Bleeder problems...
yes, they replace the original bleed screws, but you will still need someone to watch to make sure all the air bubbles are out of the lines. There is no way to pump the brakes and watch the fluid leave by yourself. the speedbleeders just have a one way check valve in them that prohibits air from entering the system through the bleeders.
  • 2 years later...
