proxlamus© Posted June 11, 2007 Share Posted June 11, 2007 Ive decided.. I hate my manual boost controller.. LoL what electric boost controllers are you guys running would recommend?! I am lookn to spend under $300 and something small and easy to work. I was interested in a greddy profec.. but ehh Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted June 11, 2007 Share Posted June 11, 2007 Why do you hate your manual? Quote Link to comment Share on other sites More sharing options...
NCchris Posted June 12, 2007 Share Posted June 12, 2007 Does this mean that you've abandoned your quest to control boost with megasquirt? I was hoping to see a success story. chris Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 12, 2007 Share Posted June 12, 2007 Blitz SBC Spec-S should do the job right, we use the Blitz controller in most all customer cars unless they want otherwise. Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted June 12, 2007 Share Posted June 12, 2007 Ya, I was hoping for a good turn out on the msns boost control too . Quote Link to comment Share on other sites More sharing options...
ARZ_ Posted June 12, 2007 Share Posted June 12, 2007 The APEX-I AVC-R This boost controller has the ability to control your boost per every 200 RPM increments AND (get this) per gear. I dont know about you but 20+ psi is a total waste in first and second gear in my car (even with sticky tires). I bought this controller and have yet to install it but plan to limit boost to 14-16 in first, to 17-19 in second and 23-25 in third and see if my Turbo is worth any more than 28 psi in 4th and 5th. This boost controller can tell you what your duty cycle is, tach, boost, and a ton of other functions. You hook the EBC up to the tach and the speedo output and then program what gear your in and then it knows what boost you will be looking for in each gear. Remember my toyota trans has a digital speed sensor on top of the speedo cable, this is what I plan to use. You might need to use the little ZX adapter wheel to get an electronic signal out of your speedo. IIRC this is a little short stub of speedo with a speedo output. If that doesn't work you you can alway use a metal ring around the input shaft of the drive shaft. Hell some s13/14/15 diffs came with a speed sensor in the diff housing. There would be many ways to accomplish the speed trigger. Quote Link to comment Share on other sites More sharing options...
hughdogz Posted June 12, 2007 Share Posted June 12, 2007 I want to know where I can buy just the solonoid unit from an Apex, greddy or Blitz (not in that particular order). I don't need the controller since I plan on using a Wolf3D. Doesn't the solonoid valve just take a voltage signal for the input? I read that these controllers are way better than the stock wastgate actuator since it will actually open up the wastegate at 7psi, not start opening it up around 5-6 psi. Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted June 13, 2007 Share Posted June 13, 2007 G-redy profec B. Simple effect. and precise Quote Link to comment Share on other sites More sharing options...
Slow_Old_Car Posted June 13, 2007 Share Posted June 13, 2007 G-redy profec B. Simple effect. and precise agreed, 3 boost levels on tap, zero problems. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 13, 2007 Share Posted June 13, 2007 Greddy profec EO-1 is pretty nice. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 13, 2007 Author Share Posted June 13, 2007 Yes I am giving up on the MS boost controller.. I would need a laptop to change the boost.. which means I have to pull it out, load it up.. change the values and give it a drive and watch the guage. OR I twist a knob. Thanks guys! Quote Link to comment Share on other sites More sharing options...
ARZ_ Posted June 14, 2007 Share Posted June 14, 2007 I want to know where I can buy just the solonoid unit from an Apex, greddy or Blitz (not in that particular order). I don't need the controller since I plan on using a Wolf3D. Do a search on Ebay for a GM solenoid controller, they are crazy precise and the same type of thing and lots cheaper. Doesn't the solonoid valve just take a voltage signal for the input? I read that these controllers are way better than the stock wastgate actuator since it will actually open up the wastegate at 7psi, not start opening it up around 5-6 psi. A pressure regulator will do the exact same thing, or even a Manual boost controller Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted June 15, 2007 Share Posted June 15, 2007 If you can find one... HKS EVC EZ It has a power button and a knob to increase and decrease boost. It holds boost rock solid and high boost Supra folk swear by them . I have used a couple of them myself and have turned a couple of others onto them as well. They can be found on Ebay occasionally for $150-$250 Regards, Mike Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted June 17, 2007 Share Posted June 17, 2007 I want to know where I can buy just the solonoid unit from an Apex, greddy or Blitz (not in that particular order). I don't need the controller since I plan on using a Wolf3D. Doesn't the solonoid valve just take a voltage signal for the input? I read that these controllers are way better than the stock wastgate actuator since it will actually open up the wastegate at 7psi, not start opening it up around 5-6 psi. Ditto on the GM solenoid. You're looking for one from a Buick GN, Turbo TA, or Syclone - they aren't real expensive. They operate using a pulsed signal. If you want an even better solenoid AEM sells some for use with their EMS but I used the GM unit to 34PSI with no issues. Honestly I think the EMS controlling the boost is best - no temptation to get stupid and push the edge on low octane gas etc. The AEM allowed multiple levels of boost and a switched input could be used too. I hooked that to a pressure solenoid on the meth injection, when meth flowed and pressurized the line I got higher boost - an empty tank left me at low boost. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted June 17, 2007 Share Posted June 17, 2007 If you can find one...HKS EVC EZ It has a power button and a knob to increase and decrease boost. It holds boost rock solid and high boost Supra folk swear by them . I have used a couple of them myself and have turned a couple of others onto them as well. They can be found on Ebay occasionally for $150-$250 Regards, Mike Just make sure it's the EZ. The EVC IV (is there a V?) has a boost limit due to the internal sensor it uses. I think it's a 2 or 2.5BAR sensor and while "smart" it's not good for high boost. Yeah, the Supra guys were the ons bitching about this Quote Link to comment Share on other sites More sharing options...
speeder Posted June 17, 2007 Share Posted June 17, 2007 Second (or Third) the HKS EVC-EZ. The newer ones, though pricey, are just as good as the old ones. Quote Link to comment Share on other sites More sharing options...
