maxtor Posted June 15, 2007 Share Posted June 15, 2007 I just found one in Southern Ca., They are shipping it up to Northern Ca. for a total cost of $266.50 From what I have been reading on this forum, that seems to be a reasonable price. It is a posi. Thanks for all the help. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 15, 2007 Share Posted June 15, 2007 Have you seen a picture of the diff with the rear cover removed? Quote Link to comment Share on other sites More sharing options...
maxtor Posted June 15, 2007 Author Share Posted June 15, 2007 No, I am taking him at his word. It is at a parts recycle place. I asked him to check to make sure that it was a lsd. He said that it was. I had him rotate one axle and make sure the other turned in the same direction, and he said that it did. We will see what it looks like when it arrives. Quote Link to comment Share on other sites More sharing options...
maxtor Posted June 15, 2007 Author Share Posted June 15, 2007 I just received a call from the store that has the differential. He had the inspection cover off and it is a 3.90 gear ratio. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 15, 2007 Share Posted June 15, 2007 Unless someone installed an LSD in it later in life, it shouldn't be a posi. The only long nose R200 that came with LSD was the 87-89 300ZX turbo, in the US anyway. I have the 200SX turbo diff as well. Mine is 4.11 and was open, and I swapped the LSD from a 300ZXT into it. Moving post to drivetrain forum. Quote Link to comment Share on other sites More sharing options...
rreford Posted June 15, 2007 Share Posted June 15, 2007 all the info i have on the 200SXT diffs says that the '84-85 units were 4.11, '86 was 3.9 - all open diffs. Have seen such in junkyards. Not posi unless swapped out at some point Quote Link to comment Share on other sites More sharing options...
maxtor Posted June 15, 2007 Author Share Posted June 15, 2007 Hmmmmmmmmmm.... If it is not posi,,, I will not be to happy. Oh well, maybe I will weld up the new R200 or find a posi for it. Quote Link to comment Share on other sites More sharing options...
johnc Posted June 16, 2007 Share Posted June 16, 2007 They are shipping it up to Northern Ca. for a total cost of $266.50 If its a 3.90 R200 with a limited slip, you just got a great deal. If not, you just paid about $166.50 too much. Also, turning wheels does NOT indicate if a rear end housing contains a LSD unit. It never has and never will. Forget anyone ever mentioned that little fable. Quote Link to comment Share on other sites More sharing options...
maxtor Posted June 16, 2007 Author Share Posted June 16, 2007 Thanks for all the information...I finally found the drivetrain section. Sorry... I see some good information with the sticky's. Looks like I paid $166.50 to much, but that is ok. I might just weld the spiders on this one, and use it for drag racing only. It will probably take me a week or two to read all the good posts in this section. Thanks again Maxtor. Quote Link to comment Share on other sites More sharing options...
