naviathan Posted July 21, 2007 Author Share Posted July 21, 2007 Ok I figured it out and I know have an RPM signal, but I'm not getting any spark at all. Everything is hooked up properly, I'm getting fuel (I can smell it) but the timing light I've got hooked up to show spark isn't flashing. When it's on the stim the IGN LED flashes so I assume that means it's out putting something. Any ideas? Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 21, 2007 Author Share Posted July 21, 2007 I now have spark on every cylinder except #1 again. I think I'm just going to go buy new plugs, wires cap and rotor now. Even though these aren't that old it's still not cranking. Someone beat me over the head with a bat please. It might be more productive. Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted July 21, 2007 Share Posted July 21, 2007 Lol. Reminds me of a time I was about to hang myself, Couldn't find the problem. Turned out my brand new NGK's had broken inside the insulator. Checked everything getting spark from every wire, fuel , etc. Would have never guessed it was the brand new plugs. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 21, 2007 Author Share Posted July 21, 2007 Funny you should mention that. It's always the simplest things. I went out and cleaned number 1 with a torch and now it's getting spark. My car hates me. Time to clean the rest of them. It still doesn't want to start. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 21, 2007 Author Share Posted July 21, 2007 Here's my datalog. With the MS triggering from the VR sensor, what should my Trigger Offset (deg) be? datalog200707211438.zip Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 21, 2007 Author Share Posted July 21, 2007 I'm up! Well sort of. I had my timing way too low. I set my trigger offset to 82 and I was able to get it start and stay running long enough to get a datalog. I had to keep feathering the gas pedal to get it going and keep it going. I think it's now a fuel issue, but I'm not sure. Here's a couple datalogs. Help me out! datalog200707211732.zip datalog200707211746.zip Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted July 22, 2007 Share Posted July 22, 2007 Congrats, now you know all the assembly and wiring is correct. Tuning is much more fun than debugging. Later, I will check out the logs and post your msq. I will suggest things if I see fit. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 22, 2007 Author Share Posted July 22, 2007 Thanks cygnus. I'm still tossing between timing and fuel. I'm not sure if I still need to tweek the timing some or go ahead and start messing with the fuel. I'm leaning more on the timing right now. I think that if I can get it to idle then I'll start playing with the fuel settings and smoothing things out. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted July 22, 2007 Share Posted July 22, 2007 Timing is easy. Ramp all your timing cells from idle 15btdc up to about 25-30btdc at 3000 rpm. Fill in the ENTIRE chart with 25-30 for all cells higher then 3000 rpms. This should be good enough for you to start making it driveable with the VE table. I am not sure what timing an N/A normally idles at but 15 should keep it fired. Once you have it running, you can go back and mess with the timing later. MAKE SURE YOUR TIMING SHOWN IN MEGATUNE MATCHES THE CRANK PULLEY WITH A TIMING LIGHT. Get it set idling at about 1000 rpms, 15btdc, and 12.5:1 AFR. That should net a pretty smooth idle. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 22, 2007 Author Share Posted July 22, 2007 That won't work with my setup. I'm running it off the VR sensor with no ignition module. I'm figuring somewhere around 50 would be a starting point. I'm still working with it though. It took 82 degrees to get it where it is now, but that was just using settings from the forum. I think it's not idling because I have the timing too high. Quote Link to comment Share on other sites More sharing options...
