Daeron Posted July 31, 2007 Share Posted July 31, 2007 My lawnmower sucks. It is an ancient craftsman bagger model, that has had three or four different engines on the frame over the course of its life. My landlord/roomate has had it forever, and has kept that one alive because he had and used the bag for it (the bag is huge) and we compost all of our yard waste and fish remains. The thing is so godawful looking that I will NOT even post a picture of it here. One front wheel is being held on with tie wire. Bad. It runs like a top, but its falling apart! So, somewhere Fletcher (my landlord) picked up this really nice Craftsman self-propelled mulching/bagging mower, I think from the dumpster at work?! I don't know. Its got a 6.75 horsepower Tecumseh engine on it, 22" cut. Just, your standard, MODERN, pretty nice self propelled mower. Nothing special.. but better than "the beast" with the broken recoil (we had to wind the rope back up manually ) We rebuilt the carburetor on it, replaced the spark plug and the air filter, and it ran like a top. Except, it had an oil leak REAL BAD, and was about ten times louder when you stood on the non exhaust side of the engine, than when you stood on the exhaust side. Rod Knock, anyone? So, no go on the new mow. Fast forward about a year to last week. My dad emailed me, saying that he had his "old" mower that he could give me, a five horse techumseh engine, it just needed a carburetor. He had rebuilt the carb on it completely, it looks beautiful.. it should run great... BUT, the carb will not run. He "got around to" rebuilding the carb on another mower he had (identical to my craftsman, actually) and wanted to know if i wanted this engine. Since I knew I had a recently rebuilt carburetor, I jumped on it. My dad also was aware that I had a need for some sort of lawnmower related parts.. we are kinda "buddies" like that, neither of us buys lawnmowers, we find "broken" ones and put them together into working ones. Its a pasttime as much as a money saver. Anyhow, I became the proud owner of a formerly self propelled, non running murray. Of course, as soon as I started taking things apart, I discovered that in the last year my nice, "rebuilt" carburetor had gotten all fouled up with junk and nastiness... wonderful. Re Rebuild time! Eventually got it taken care of, and in the course of this discovered that the bore on the 5 horse murray carb was about 60% of the size of the bore on the craftsman carb.. I am imagining that a large amount of the horsepower increase is from this bore change alone. The craftsman also had a different cylinder head, with the intake port on the bottom, and the craftsman intake manifold, as a result, had a downward slope to it. Other than that, the two engines were identical. The air filter setup, and the carburetors, were somewhat different though. There was some sort of vacuum line? coming out of the rear of the block, and on the murray it went into the air filter housing; whereas on the craftsman it went directly to a second hose barb on the carb. This barb appeared to lead into a red straw that snuck through the bore, and out into the air filter; without the air filter this carb will NOT run. So, step one (after the carb rebuild, heh) was to remove the engine cover, air filter, oil filler and gas tank assembly from the murray and replace it with the pieces from the craftsman. The craftsman recoil had a busted rope, so I just used the murray recoil. Lo!! And Behold.. Yah, the 5 horse has stripped exhaust threads, must JB weld that in the near future. But that is the same motor that was on the red frame.. with the carb and trimmings of the cratsman on it. It started fine, but wouldn't keep running after it started. The air filter was sopping wet, and I chalked it up to that, end afternoon 1. So today I got off from work early, and went out to beat my head against it, and sweat some more. (a lot more, actually..) I began by confirming that it ran good with a dry air filter, and set to removing the engine from the craftsman, examining the drive assembly (this is the first self propelled lawnmower I have had my fingers into) and making sure everything was going to be a direct swap as anticipated. Really, it is amazing how rarely I have seen two lawnmowers whose engines could not theoretically at least be swapped. It takes a serious oddball brand to be different. There were several minor issues that I wont bore you with details on; suffice it to say that I had to get inventive to retain both the blade brake, and find a way to activate the drive mechanism, because the cables that I had and the levers that I had did not all match up. In the end I had to kinda pinch the handle assembly from the murray, and put it on the craftsman, to get it to work right. I also had to use the original craftsman blade brake cable on the drive, and use the murray brake cable on the blade brake. On top of the "accesory witching", the blades had different methods of staying locked to the output shaft, and the blade for the engine we used was shot (and smaller) so there was a minor bit of ingenuity there as well.. but otherwise it went easy as pie. And so here we are. Back to where we started, appearance-wise anyhow. There are two covers still uninstalled in these pictures, because they were taken right after mowing the first trial patch. As soon as I had this thing together, on the very first successful start, I pushed it out for a victory lap around the weeds in the back. Runs great. You can see some fresh gore on her, from her battle out in the yard. Aint life grand? here is a gratuitous shot of my admired and appreciated assistant: and the aftermath: I really want to paint the deck, now. I DEFINITELY plan on removing the Craftsman badging and stencilling DAERON on there somewhere, ad the very least. I am not bragging about my insane skills, or anything.. Just sharing something I thought might be interesting to some of you people walking a less unusual path than I To those who understand what I did, and have done the same, I salute you! This kinda tinkering is fun, and beneficial; I take garbage and turn it into a $300 lawnmower And finally... What I am about to say I mean on so many different levels.... THANKS, DAD!!! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted July 31, 2007 Share Posted July 31, 2007 you have to much time on your hands.... not only to do all that tinkering but more imporantly you had the time to write up that LONG post about a LAWNMOWER!!!! lol but ehh w/e at least you have a lawn mower now Quote Link to comment Share on other sites More sharing options...
Daeron Posted July 31, 2007 Author Share Posted July 31, 2007 i knew i was gonna get my balls busted for that, heh. The lawnmower was fun, believe it or not.. the write up was what I did while I sat in my bedroom and cooled off. Quote Link to comment Share on other sites More sharing options...
primadonna z Posted July 31, 2007 Share Posted July 31, 2007 Now that we have the silly stuff outa the way. Either one of you Florida boys gona be in Daytona the first week of October (ie: Nat. Convention)?? And I agree....Way to much time on you hands. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted July 31, 2007 Share Posted July 31, 2007 i live in daytona so yeah. im going to try and take the whole week off.. well tht is if i dont get hired onto the elevator union by then. Quote Link to comment Share on other sites More sharing options...
dsommer Posted July 31, 2007 Share Posted July 31, 2007 My Honda lawn mower took a crap on me the other day wanna swing by and install a 350 Chevy on it? Quote Link to comment Share on other sites More sharing options...
Trevor Posted July 31, 2007 Share Posted July 31, 2007 I've got a 12-year-old MTD mower that I kept 'cause I liked the deck -- its self-propelled, and has one lever to adjust the height of all 4 wheels. I have worn out the original 5.5HP Techumseh and for a I while ran a used 5HP Briggs that just needed a new flywheel shear pin. Later the coil went bad and I didn't have a cheap replacement so I splurged on a new engine Currently it has a 6.5HP Honda that I bought mail-order from Northern Hydraulics. It's like getting a new mower for $120. Quote Link to comment Share on other sites More sharing options...
strotter Posted July 31, 2007 Share Posted July 31, 2007 You know what's sad? What's sad is that I was really into the story. I'm reading, and I'm kind of muttering to myself "So what's he going to do with the - hey, is that a new carb on that motor, or the old one... wait ... Oh, I see! Hmm, he's going to have to do something with the self-propel system ... Oh, cool! That's cool! ... " Quote Link to comment Share on other sites More sharing options...
Datsun350Z Posted July 31, 2007 Share Posted July 31, 2007 Pretty sweet. You may possibly have too much time on your hands, but still a worthwhile project. Check this out for your next project: And if you still need more power: Quote Link to comment Share on other sites More sharing options...
ckelly78z Posted August 1, 2007 Share Posted August 1, 2007 And thus starts your film/storytelling career. Quote Link to comment Share on other sites More sharing options...
Daeron Posted August 1, 2007 Author Share Posted August 1, 2007 bitchin, I knew I would get SOME sort of positive response. As for the convention... I'm poor enough to be rebuilding a junk lawnmower. I think that says enough, heh. I will make it to the conventions when my posts have something to do with my car, deal? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 2, 2007 Share Posted August 2, 2007 I'm poor enough to be rebuilding a junk lawnmower. That's how you learn: when you are too poor or too cheap to buy new, you tinker with the old stuff to make it all work. "Ingenuity is the mother of invention," and the dead beat dad of tinkering isn't too far behind Good read! Davy Quote Link to comment Share on other sites More sharing options...
Daeron Posted August 2, 2007 Author Share Posted August 2, 2007 Good read! Davy Thanks, thats really all I was going for. Words are another one of my "things." (read: I talk too much ) Quote Link to comment Share on other sites More sharing options...
johnc Posted August 2, 2007 Share Posted August 2, 2007 Had a neighbor who put a 125cc two stroke Yamaha YZ engine on his mower. First time he ran it up to 5,000+ rpm the steel blade snapped at the center bolt and the two halves shot through the sides of the mower. One blade stuck 4" into a railroad tie and the other shot into the garage and skewered a metal trash can. Quote Link to comment Share on other sites More sharing options...
Pete84 Posted August 2, 2007 Share Posted August 2, 2007 Had a neighbor who put a 125cc two stroke Yamaha YZ engine on his mower. First time he ran it up to 5,000+ rpm the steel blade snapped at the center bolt and the two halves shot through the sides of the mower. One blade stuck 4" into a railroad tie and the other shot into the garage and skewered a metal trash can. He needs to get a forged blade then I'd say. Then get it balanced. Wouldn't have to slow down from a steady jog with that Quote Link to comment Share on other sites More sharing options...
Collectindust240Z Posted August 2, 2007 Share Posted August 2, 2007 Where can I get one of those TypeR mowers?!! That thing is bitchin!! Isn't photoshop grand? Maybe we can make a Mustang ride on. Quote Link to comment Share on other sites More sharing options...
strotter Posted August 3, 2007 Share Posted August 3, 2007 "With his mower project done and feeling he needed a real challenge, Daeron's attention turned to other things that needed doing..." Quote Link to comment Share on other sites More sharing options...
Daeron Posted August 3, 2007 Author Share Posted August 3, 2007 i might be able to make a proper response to that tomorrow. Thanks for sending me on a laugh track right before bed, heh. Didn't see THAT coming a mile away! Quote Link to comment Share on other sites More sharing options...
