Brake Master Cylinder Leak
I recently installed a new Master cylinder on a 72 240Z. There appears to be a leak at the fitting of the rear brake hard pipe where it is attached to the MC or at the large nut where it screws into the bottom of the MC directly under the reservoir for the rear brakes. I can detect fluid between the large nut and the main body of the MC and, over a few days, fluid builds up around the fitting for the rear brake line where it screws into the large nut. I assumed being a new MC they would have properly tightened that large nut at the facory. I have the rear brake fitting that bolts to the MC as tight as I can get it with out risking stripping the threads. I thought of pulling the MC and tightening the large nut the rear fitting screws into. I was also wondering if there may be a problem with the fitting that screws into the MC. Is it ok to put plumbers tape on the threads? Should I go buy a new hard pipe and fitting?
Thanks
Miles
I'd take it back and get another one. Beauty of having new parts and a receipt! The brake fitting seal is a flare fitting. There should be ZERO fluid getting past this to the threads so telfon tape is not the answer. (This doesn't keep fluid from leaking past the tube through the center of the fitting anyway.)
