Ezwiring Guide ............ Still not complete
tkach
Ok here it is my ezwiring 1975 280z wiring guide. It is currently incomplete and I still have a few parts to workout. They are
1) How to wire up reverse lights
2) Where to source the power for my tail lights (use third break light power?)
3) What powers all my gauge's? this issue stems from the fact that according to my diagram i have to wires running into the light bulbs within the gauge's, a green white and a red blue. However the ez only shows 1 wire for this light . Thinking the the red blue runs threw my dash dimmer and alters the current flow to dim my lights? and how to hook up my dash dimmer?
4)What circuit I want to use to power my ignition box (msd unit).
anyway this is what I have worked out thus far. It shows what color the wires are and what they do
and how to connect them to your Ez harness . I hope it serves as a good starting point for others. I know that others have broken down other sections of their Z harness and how it mates to the EZ please post and help out!
**note connections are as follows describes the original wire color first then the EZ harness color after
Rear Section
Left Side Right Side Lamp
Wire Color Action
Black Yellow Stop
Red Black Reverse
Green White Tail
Green Red Turn
Black Ground
Connections are as follows
Green White Brown
Green Red Yellow
Red Black
Black Yellow Stop switch
Right Side Right Side Lamp
Wire Color Action
Black Yellow Stop
Red Black Reverse
Green White Tail
Green Black Turn
Black Ground
Green White Brown
Green Black Green
Red Black
***Note Stop Switch connects to fuse panel
License Plate
Wire Color Action
Green White power
Green White Brown
To Lower Chassis
Wire Color Action
Yellow To Fuel Gauge
Yellow Blue To fuel warning lamp
Green Blue Fuel Pump Power
Yellow Pink
Green blue
Dome Light
Wire Color Action
Red White Into Drivers Seat Switch To Assorted Seat Switch To fuse Box to ignition interlock
Black Red Door Switch Right Hand to C-1
Black Ground
Red White White
Brown to door jam switches
Black Ground
Dash
Dash General
Wire Color Action
Red blue To control Panel illumination Lamp Runs to Radio and hazard Switch
Green White To Light wiper washer combo switch Runs also to glove box lamp
Front Section of Z to T/S park lamps
Black Ground
Red blue
Green White Brown
Amp Meter
See Notes in book for more Install information
Wire Color Action
Green To Speedo
White To Shunt Split into two sections
Fusible Link to starter Terminal with B wire From Battery Pos
Voltage Regulator
White- Route the 10 gauge solenoid pwr = red wire from the fuse panel to the amp meter and then from the other post of the amp
meter out to your pos bat source.
Oil Pressure
Wire Color Action
Yellow Black Oil Pressure Switch
Yellow Black Lt Blue/Black
Fuel Gauge
Wire Color Action
Yellow Fuel Gague level Reading Unit
Yellow Pink
Tacho
Wire Color Action
Green To Voltage Regulator F to water temp rely to fuse box
Blue To 15k resistor to tach terminal neg on hei
Black White Bat Terminal on HEI
Note When Adjusting tach turn 45 degrees clockwise
Green Red To combination switch then to LH T/S light
Green Black To combination Switch then to RH T/S light
Green Red- White
Green Red LT Blue
Green Black Blue
Power from Purple white
Speedo
Wire Color Action
Red to fuse box then to Head lamp RH the fuse box R cont to run to light wiper washer switch
Note the RY line from the LH head Lamp also runs into the fusebox
Green Yellow Brake System Switch to parking break switch.
Yellow To interlock Realy to Neutral Safety Switch.
Red Lt Green
Water Temp
Wire Color Action
Yellow White Temp Indicator
Yellow White Green
I don't have the 280z diagram, but this is for a 240z...
1. Backup + backup power to reverse switch on trans
2. heavy red "lights power" to combo switch blue/green were
3. there is a wire called "guage" that is the power for the guages, not the guage lights. use park or tail wire for guage lights. one wire is ground and one power. you can make your own ground. the power wire goes to a reostat, then from the reostat to the gauge lights.
4. I dont have mine wired to msd, but you will need to have a switched ign on wire attached + coil and distributor wire (I think)
280Z-75 thanks i have been workin off that diagram tho. On a side note this morning when i got home from work i figured id strip some more of the wire out of the Z, I didn't pay attention and sliced my pinky and ring finger open! so after a number of stitch's 6 in the pinky 4 in the ring finger to be exact i figure i better get a move on this harness 'cuse the car is starting to bite back!
Your timing is perfect on this post - I'll be working on my 240 this weekend. I stripped everything out of my Z, and there is no dash gauges to speak of - so mine will be slightly different. however, the rear lights info is great - thanks! If I have any feedback/updates, I'll post them.
-Bob
Since my notes are a bit cryptic I wanted to draw out an actuall diagram so that everyone can understand it, making it as EZ as possible...har har. demand is high though so here they are!
"Starting with the left switch (turn signal & brights)
Switch Harness
Green ---> Purple 25 turn flasher
Green/blk ----> Green 26 Horn switch
White/Red ----> connect to 3 wires:
Blue: 21 R rear turn
16 R signal ind.
17 R front turn
White/Blk -----> Connect to 3 wires:
Blue 14 Left signal indicator
light blue 15 Left front signal
yellow 20 Left rear signal
Red/white -----> connect to 2 wires:
Green 28 Left high beam
Green 73 high beam indicator
Red/Yellow -----> Light brown 24 Left low beam
****The
previous ground goes to the White/Red of the head light control.
Head light control switch:
Green/white ---------> connect to 2 wires
brown 48 Left front park
? ? Left rear park
Green/Blue --------> Red 33 Switch power
*** note the red 33 splits into red and black,
Connect black side to Green/Blue
Red ---------> Red 01 headlight power
Ignition Switch
Blue/Red ---------> Peach 31 Ignition switch acc
Brown 29 Ignition Switch
Black/blue ---------> Purple 32 Ignition switch start
Black/White ---------> Pink 30 Ignition switch coil
White/Red --------> 33 red ** this connects to
the red side of the above note.
So thats its, It should be a good start, just be sure to keep your multimeter out and check continuity in the switch as you wire things in. It can be a bit intimidating, but its really EZ...and if you do wire something wrong, the fuses will most likely blow when you connect the battery! "
so got some more stuff done I hope that this is help to sombody at some point
Front End of Chassis
Headlight Right Head
Wire Color Action
Red Power from fuse box/ breaks off and runs into speedo
Red White to speedo red white then to combo switch high beams 15
Red Black To combo switch low beam 16
Red white light green then to Speedo
Red red 01 headlight power red black
Red black tan
Headlight left Head
Wire Color Action
Red yellow power from fuse box
Red White to Speedo red white then to combo switch high beams 15
Red black tan
*****note headlights wire run together
Wiper Motor
Wire Color Action
Yellow P on amp assy Int Wiper
Blue Red to blue white to yellow green to combo Switch Wiper 2
Black Ground
Yellow Green to combo switch wiper 2
Yellow Black to combo switch wiper L
Blue yellow to wiper H on combo switch
Blue red wiper motor power
Now time for a nice little write-up on the wiper
From http://www.atlanticz.ca/zclub/techtips/wipermotor/index.htm
The Z harness, as I wired it, which I don't fully understand:
6 prong harness:
-1- -2- -3-
-4- -5- -6-
1: 12v, blue/red.
2: Ground, black.
3: No idea, maybe allows for proper stop/set of wipers
4: No idea, maybe allows for stop/set, seemed to read fluctuating voltage when engaged.
5: High speed, either blue or blue/yellow. Don’t remember, will update
6: Low, intermittent, and washer. Probably relay driven. Blue or blue/yellow.
amp assy Int Wiper
Blue to wiper combo switch I
Blue Red From Fuse to wiper B amp assy int wiper to combo switch wiper
Yellow To wiper motor
Yellow green to combo switch wiper 2 Blue red from wiper motor intersects
Blue White to combo switch W for washer motor
Blue Yellow to combo switch 3
Black Ground
Blue red wiper power
Break system switch
Wire Color Action
Green yellow to Speedo then splits off to parking break switch
Turn Signal and park lamp right hand side
Wire Color Action
Black Ground
Green White Power
Green Black to combo switch 11 to green black on tach
Black ground
Green black lt green
Green white brown
Turn Signal and park lamp left hand side
Wire Color Action
Black Ground
Green White Power
Green Red to combo switch 10 to green red in on tach
Black ground
Green red lt blue
Green white brown
Horn
Wire Color Action
Green white power to horn from really
Green red from fuse panel to power horn
Green black to combo switch 18 horn ground
Horn
Green white green
Green red from fuse box
Green black to combo switch 18 horn ground.
  • 4 years later...
  • 4 weeks later...
