Low fuel pressure
Guest powerman
Guest powerman
Vehicle info: Mainly stock 77 280 with a 78 L28 in it. Cold air intake, MSA large throttle body, headers and exhaust.
Problem: It has been sometime since I did the engine swap and I have remembered that the donor car that I got my engine out of had a lot of fuel pressure gauges on it. (after fuel filter and a sender to read it from the dash) This led me to believe that it may of been having a problem.(duh) I put a pressure gauge in after the fuel filter to check my pressure. It reads 30 psi a idle. I checked the factory manual and its should be 36 psi I believe. I have replaced the fuel filter and the pressure regulator to narrow it down. Now I'm thinking it could be clogged lines, fuel damper, or a failing pump. What do you guys think?
If you have a restriction, clog, or failing fuel pump, that 30 psi at idle will drop a huge amount when the revs come up with some load. Disconnect the vac line to it and see if it steady as the revs increase or better if you can see it while driving at WOT. If it stays pretty much at what it is at idle( assuming the vac line is off), it's the regulator.
The pressure depends on the amount of vacuum.
High vacuum causes low pressure due to a vacuum sensitive FPR
My car idles at 26 psi and drops to 22 during deceleration.
36 to 38 psi at WOT (zero vacuum). You can unplug the vacuum hose from the fuel pressure regulator to simulate WOT.
Guest powerman
Ok I looked at the gauge while it was under a load and the pressure went up. This should happen since it stays "36" psi over the manifold pressure (I think). I took the vac hose off and it went to 36-38 psi.
When it was unplugged (zero vacuum) it went to 36-38. So this is normal then? As long as it is correct when under a load is important?
  • Administrators
Yes.
Yes... sort of... based on your description, your fuel pressure is pretty high with the vacuum line attached. This *implies* that your engine is not making much vacuum.
At this point, I'd recommend buying a cheap vacuum gauge and letting us know what your idle vacuum reads.
  • 2 months later...
  • 4 weeks later...
Guest powerman
What would really help us if the OP would respond to suggestions given to their questions. If they worked or not or what they did that fixed a problem.
Sorry about that, I just got out of Navy boot camp and was sorting through my email (a huge pain may I add) and I saw that the thread had a reply.
I didn't end up fixing anything. It runs and runs well, no missing or dramatic loss of power. The fuel pressure is normal when it is being driven. I robbed the pressure guage off of the old on and drove the car with it. I don't have time to mess around on it anymore so it will stay as it is untill something actually goes wrong.
You know what they say; "If it ain't broke, don't fix it."
then my personal favorite for the Z "If it ain't broke, fix it until it is."
