RUSSJZ-ZED Posted September 26, 2007 Share Posted September 26, 2007 The front pan will not work in a J series into a 240/260/280Z,(unless your names Mandrake) there is a mid pan and a rear pan, what cars did the mid and rear pans come out on?I'm not even sure which one of these I have, anyone know? I suspect it's a mid, but dont know what it was from, anyone have a pic of the last of the set? I have been told the mid one is the hardest one to find. Front sump/pan on 2J tt on left. my ??? on right. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted September 26, 2007 Share Posted September 26, 2007 There's a front and a mid sump, but I guess it is far enough back that some people call it a rear sump. I believe the 1JZ supras came with the rear sump. Mario Quote Link to comment Share on other sites More sharing options...
oatmilk Posted September 26, 2007 Share Posted September 26, 2007 "I'm not even sure which one of these I have, anyone know?" From my in person viewing experience, all MKIV Supras, SC300's with M/T and 1JZ's that came out of a MK3 Supra (japan only) all came with mid-sump(aka rear-sump) pans. All of the Aristos 2jz's that i have seen come with front sump pans. I still have my front sumps stuff. So my guess is that your pan came from one of the above. I'm not sure on Cressida's. I haven't researched them much. I thought they were front sump as well. Us USA guys have it easy as all we have to do is order all of the parts for a MKIV Supra oil pan from our local dealer: upper pan(cast piece) lower pan(stamped steel piece that actually holds the oil oil splash plate/cover oil pick-up tube of Toyota FIPG 1207B gasket maker silicone(black silicone) Replace all the parts above when you remove the like parts from your front sump 2jzgte and your ready to go. This has been my experience to date. Hope that helps. Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted September 26, 2007 Author Share Posted September 26, 2007 So the mid pan and rear pan are one and the same? Explains why I have only come across the two types. (Cressidas -late '80s early '90s in this Country were nearly all 7M non turbo, the guys converting to 1J/2J need the front pan/sump because of position of crossmember, The Mid/rear ones are 2 a penny, front pans are rocking horse sh1t , I think only from Aristo and Chaser) Quote Link to comment Share on other sites More sharing options...
theianmonster Posted September 26, 2007 Share Posted September 26, 2007 Supra - Rear sump. Chaser - Front sump. Quote Link to comment Share on other sites More sharing options...
Careless Posted September 27, 2007 Share Posted September 27, 2007 If you know the part number for either pan, toyota usa/japan will ship it to whatever dealership you order it at. Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted September 28, 2007 Author Share Posted September 28, 2007 I think Toyota might work out a touch too expensive if you are stuck with the wrong pan, might be a bit kinder to the wallet used. Parts needed to swap-All straight bolt on,All different. Oil pan Alloy skirt baffle plates Dip stick tube dip stick Quote Link to comment Share on other sites More sharing options...
theianmonster Posted October 1, 2007 Share Posted October 1, 2007 I got a price for about $125 for a pan from Toyota. The 2JZ pan will fit a 1JZ, its the same block, just the 2JZ block is taller. Quote Link to comment Share on other sites More sharing options...
Careless Posted October 1, 2007 Share Posted October 1, 2007 I think Toyota might work out a touch too expensive if you are stuck with the wrong pan, might be a bit kinder to the wallet used.Parts needed to swap-All straight bolt on,All different. Oil pan Alloy skirt baffle plates Dip stick tube dip stick you won't end up with the wrong pan if you get the right part numbers for what you need. plain and simple. I would just go new on everything at the bottom of the engine, just to be extra safe. oil pans are re-usable and that's fine. But i would get a new sump pickup for sure Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted October 1, 2007 Author Share Posted October 1, 2007 Woops! I stupidly left this "useful" little part off the list. Could work out expensive if left out:icon_frow. ( I suspect mnstr-techica's $125 price from Toyota is only for the tin pan-I know that Toyota Australia would not sell you the time of day for that amount) Quote Link to comment Share on other sites More sharing options...
oatmilk Posted October 1, 2007 Share Posted October 1, 2007 Both these guys ship around the world on Supraforums: Champion / Jay Marks Toyota ask for Jay or David Gin the Parts Dept. Champion Toyota (Jay Marks) Parts Department David G. / http://www.toyotaworld.com Retail and Internet Sales 800-327-2087 713-943-7010 Guaranteed best price & service! 2jzgte parts prices Upper pan: 352.39 List 252.10 Sale - In stock Lower pan: 125.26 List 89.62 Sale - In stock Pan baffle: 13.55 List 9.69 Sale - In stock Elmhurst Toyota Scion ask for Curt 630-279-2265 - Unmatched service Parts list to convert over to a rear sump. Its for a 1jz but 2jz should be the same: 90182-06005 NUT LIST .55 COST .41 X 2 91621-60612 BOLT LIST .60 COST .44 X 1 15147-AD010 GASKET LIST 2.40 COST 1.77 X 1 15104-46030 STRAINER LIST 45.96 COST 33.98 X 1 12111-46052 PAN UPPER LIST 352.98 COST 264.92 X 1 12121-46030 PLATE, LIST 13.00 COST 9.62 X 1 12102-46031 PAN LOWER LIST 125.15 COST 94.84 X 1 90430-12031 DRAIN PLUG GASKET LIST .98 COST .73 X 1 90341-12012 DRAIN PLUG LIST 3.66 COST 2.71 X 1 96721-24031 O RING LIST 2.54 COST 1.88 X 1 91512-B1055 BOLT LIST 1.18 COST .87 X 6 91511-J0820 BOLT LIST .71 COST .53 X 16 90116-06127 STUD LIST .71 COST .53 X 4 90119-06624 BOLT LIST .80 COST .59 X 23 90182-06257 NUT LIST .49 COST .36 X 2 00295-00103 FIPG PAN SEALER LIST 12.78 COST 9.36 X 2 Quote Link to comment Share on other sites More sharing options...
Guest cturbo28 Posted October 10, 2007 Share Posted October 10, 2007 I found this illustration of the 1JZ sumps. hope this helps. http://www.jzgte.com/tech/1jzgte/1J%20sump%20differences.jpg Quote Link to comment Share on other sites More sharing options...
