will these fit?(pics)
so i went to 18racing.com one of the only sites that i found really usefull for z specific wheel sizes in the wheel thread or whatever and i was wondering will these fit under the wheel well although they have a +04 offset.. i'm under the impression that the wider you go the more negative of an offset i would need with my bolt pattern but i'm not sure about if a +04 offset would prevent these wheels from fitting.. as of right now my car is sitting b/c my mag rims are all wobbled out and i don't feel safe driving them the way they are so anyways i'm jus wondering
the wheels are 17x7.5 and they also have a set that are 17x8.5 with a +04 offset
:flamedevi From what I can see. You will need some spacers for it to fit. But I don't know everything about your Z. If you have coil-overs and camber plates, it will change some. I have 16" by 7" rims on my Z now with the same back spacing. I have a 1" spacer on mine. Only have lowering springs on it.:burnout:
cool, all i have done suspension wise is tokico illumina shocks and springs so i guess you could say everything else is stock... i don't think i would need spacers i think if anything they would stick out even more with the spacers on.
You really ought to read the forum rules. Not trying to be a Nazi, but you double posted a moment ago on the 2jz v. RB and clearly didn't search on this one.
BUT... good news, I'm organizing a group buy on the RB's in the "Group Buy" section if you are interested. Also, I believe Bartman has some experience with the 17x8.5" +4
yeah my bad on the whole double post thing, i really wasn't trying to start any problems but i did search the forums about wheel sizes and offsets but i can never seem to find a clear answer on what will and wont fit under our stock fenders and what wheels actually work on our cars.. i think in the near future i'll be spending a few HOURS/DAYS searching this site for all the good info and trying to put it all in one thread... it seems like i get on this site sometimes and i'm just searching for 30-40 minutes b4 i ever find what i'm looking for.. its kinda frustrating but i understand that i need to search the forum more so i will my bad..
And you never will because there are so many variables.
Ride height
Camber
Rotor diameter
Hub offset
Bolt pattern
Stud length
Brake caliper
OEM springs
Coil overs (8", 10", 12", 2.25" OD, 2.5" OD)
Stock fender
Flared fenders
Muffler
You have to measure and figure it out for your particular car. If you're looking for easy answers, there aren't any.
Ride height
Camber
Rotor diameter
Hub offset
Bolt pattern
Stud length
Brake caliper
OEM springs
Stock fender
Flared fenders
Muffler
yea i meant with stock brakes and stock/a little lowered z.. i'm pretty sure with all those other variables you listed it would be a hastle trying to figure out what would fit on the s30... i'm just saying if i could find and post a basic list of known wheels and sizes that fit on an s30 that has little or no modification done to the suspension, that would give alot of people something to able to gauge off of.. it may not be perfect but it'll be close to what should be expected
