Jeff Posted October 17, 2007 Share Posted October 17, 2007 That looks pretty solid but I agree with the comments to add some gussets. Just be careful when you fire that thing up. I love your hoist by the way, very nice. Yes, it's an inside joke for those wondering and no worries Jeff I don't need it back yet. Quote Link to comment Share on other sites More sharing options...
LLave Posted October 17, 2007 Share Posted October 17, 2007 The only thing I would worry about is it tipping towards the front of the motor. Im sure its pretty rear heavy but it looks like it could tip forward. Quote Link to comment Share on other sites More sharing options...
JSM Posted October 17, 2007 Author Share Posted October 17, 2007 That looks pretty solid but I agree with the comments to add some gussets. Just be careful when you fire that thing up. I love your hoist by the way, very nice. Yes, it's an inside joke for those wondering and no worries Jeff I don't need it back yet. ROFLMAO! Thanks again! Just let me know when you need it back and I will bring it right back! Quote Link to comment Share on other sites More sharing options...
speeder Posted October 18, 2007 Share Posted October 18, 2007 I used to have a 3-wheeled engine stand that had a Vee-Dub bellhousing attached. With a newly rebuilt engine bolted on and with a battery and coffee can gas container I could run the engine to break in a cam, then let it cool down for head torquing before installation in the car. At first I worried about the torque from revving the 40 hp engine tipping the stand, but it proved remarkably stable. You should be fine with that stand. I'm thinking about making a test stand for my Buick engine out of angle iron, to run in the engine and also to mock up motor mounts. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 18, 2007 Share Posted October 18, 2007 I think that stand should work fine, as long as you don't go crazy with it. I used to start my engines, all SBCs, on the ground sitting on a set of crappy headers and a block of wood under the oil pan. It worked fine for break in or to see if a recently aquired engine was worth putting in a car, but if you hit the throttle too hard it would lift up fairly easily and flipping over could have been acheived. So after doing this for awhile and seeing no end to the need to run engines out of cars, I decided to make the propper contraption for such a deed. This is what I came up with... mock up with busted block The test engine I made mine around the SBC, but it is adjustable to a certain extent. I built it so the mounts change out with one bolt, so if you wanted to put say a small block ford on it you would just need to fab up different mounts to pop in the stand. The rear mount can even be addapted. All the sliding peices have two pinch bolts to hold it steady. I added the wheels for ease of movement and because I wanted to be able to store it. I wondered if it was going to roll or move around with an engine running, but it didn't move at all. As it sits here it's not quite done, I plan on adding a radiator, and a control panel with guages. This only took me two days to design and build and it's only about $80 worth of materials. Just thought I would show you what can be done rather easilly and cheaply, it was fun too. Here's a vid --- - - - - http://www.youtube.com/watch?v=OEEeNS5VRbo Quote Link to comment Share on other sites More sharing options...
JSM Posted October 18, 2007 Author Share Posted October 18, 2007 A very nice contraption indeed! Quote Link to comment Share on other sites More sharing options...
speeder Posted October 19, 2007 Share Posted October 19, 2007 X2^^^^ A very nice contraption indeed! Quote Link to comment Share on other sites More sharing options...
