SR_man_49 Posted October 23, 2007 Share Posted October 23, 2007 For the past few months I've been swaping the L28ET into my 240sx. Tonight I finally got to attempt to start it. The problem Im having is that its cranking over but its not starting. Here is what I know. The starter is good The fuel pump is good Im getting spark I've got gas The harness is good. Im pretty sure I did the timing right. I dont have the alternator hooked up but i dont think that would be the issue. Any Idea's? Quote Link to comment Share on other sites More sharing options...
das_hef Posted November 12, 2007 Share Posted November 12, 2007 im no expert, but im pretty sure your alternator needs to be hooked up for your engine to start. Quote Link to comment Share on other sites More sharing options...
Comrade_Charlie Posted November 15, 2007 Share Posted November 15, 2007 grounds? my cousin couldnt start his 300zx because some ground on the tranny was disconnected, just an idea. I dont know about the altenator doesnt seem like it would matter. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted November 15, 2007 Share Posted November 15, 2007 If you're using the L28 harness, did you get the fuel pump controller used in 1982 and 1983 cars? What year harness and engine? Quote Link to comment Share on other sites More sharing options...
SR_man_49 Posted December 10, 2007 Author Share Posted December 10, 2007 I got it started guys, I had my timing way off! lol, anyways i got that fixed and it starts but I have no compression in my #2 cyl . All other cyl's have 120 ~ 140psi, but #2 is 0psi. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Careless Posted December 11, 2007 Share Posted December 11, 2007 I got it started guys, I had my timing way off! lol, anyways i got that fixed and it starts but I have no compression in my #2 cyl . All other cyl's have 120 ~ 140psi, but #2 is 0psi. Any Ideas? perhaps one of your valves are bent or not sealing properly, your piston ring is chewed, or your spark plug seat is damaged. take your time, don't jump to conclusions. Quote Link to comment Share on other sites More sharing options...
Kash Posted January 4, 2008 Share Posted January 4, 2008 Zero psi has to be an open/ bent valve. Quote Link to comment Share on other sites More sharing options...
SR_man_49 Posted January 30, 2008 Author Share Posted January 30, 2008 Well my compression problem turned out to be a cracked head and a bad valve seat. I got a new head and just had a valve job done. Now im sitting at 150psi ~ 170psi. Considering im running flat top N/A pistons is this good compression?? Quote Link to comment Share on other sites More sharing options...
