What tranny is this?
NismoZ
Hi all, I have a quick question about a tranny i bought today at the local junk yard.Sorry if this should be known but i have searched and have found no answers to this. Anyways i found this tranny laying by a 1982 280zx 2+2 and wanted to know if this was the tranny that went to it, it has a flat plate by the shifter with a sensor by it.thanks
looks a lot like my 4 speed, but can't say for sure. i've only ever seen the bottom of it, and from my shifter hole, it looks as it would from the top.
but I think the clutch fork hole is on the opposite side, no?
id like to know too.
perhaps its a 5speed (not BW T5 though)
this website shows similarities:
http://www.zhome.com/ZCMnL/tech/BorgWarner.htm
I hope its a 5 speed since i bought it to convert my z.Thanks for the link i saw that one when i was searching around and thought i found my answer, the only thing is it doesn't have the flat plate and sensor on the top.So im still iffy about it.
I have only seen one Type A (1979-1980) in person but have owned several Type B (1981-1983) transmissions. From looking at the pictures you have posted the tail portion of the transmission looks less like the Type B's that I have owned and more like the Type A that I had seen. I do not know off the top of my head what the numbers are or where they are located, I have been running a T5 for a number of years now and have not paid much attention to the "normal" Nissan transmissions for a long time.
Dragonfly
well i just pulled the cog out and it has a yellow 16 tooth cog in it, so i dont know.
The color of the cog indicates what the rear diff gear ratio was, there are several different colors and each color is for a different ratio. If I remember correctly the yellow is for a 3.7:1 diff which was common in the 2+2 280ZX's, so that increases your chances of it being from that car, which in turn increases your chances that it is a Type B.
I may have in the back on old (very dead) Type B transmission, I will take a look tommorow afternoon and give you a better answer then if no one else jumps in here before then and gives you an absolute answer.
Funny but there is only mention of inline six nissans in this thread and a first generation maxima is a inlline six nissan.
Did someone write "R200" in invisible text on this thread because I'm just not seeing it?
Also.........many pre 1981 280zx came with 3.7 R180s.
In 20 years at various nissan dealerships, I have seen many.
Not in the US.
COUGH.
The US market cars are all Japanese cars. The ratio existed. Nothing was stopping it from turning up should somebody have specifically ordered it, and as far as I know US Customs didn't turn away those 'GI Bride' non-US market cars that keep we see turning up over there from time to time. Never say never.
( nasty cough you have there by the way )......
that trans looks like my 4 speed with that plate on top of it. and a yellow 16 tooth cog would specify a 3.36 ratio, not 3.7.
I've been looking all over for my list of color to ratio for the gears and as of yet have not found it, but I did find a partial list that indicates you are correct.
I looked at the Type B 5 speed I have in the back and the transmission shown in the above pictures is not the same, there are to many differances in the tail portion. My 260 FSM shows a picture of a 4 speed that resembles the pictures posted above but they are all sketch pictures and I can not say for sure if it is the same.
There was NEVER a 3.7 offered in a inline six powered car. Only in the Z31,s.
Here is one of the places my information came from. http://www.zhome.com/ZCMnL/tech/GearRatios.html
Contributed By: the Members of the IZCC
Produced by: Carl Beck IZCC #260
Special Thanks to: Steve Golik-IZCC #356, Tom Bell-IZCC #2802 & Ross Corrigan-IZCC # 255
The Purpose of this page is to give you a quick reference listing of the gear ratios used in the various models of the Z Car. We will try to include both transmission and rear end gear ratios FYI.
As of 12 Mar. 2000 -cjb
Standard Differentials & Rear Gear Ratio's
This is the list that we came up with, after discussion on the Z Car List, and review by the subscribers there.
Standard Rear End's as Delivered From The Factory 1969-1989 :
240Z 70-73 MT (3.364) (R180)
240Z 70-73 MT 5spd. (3.900) (R180) - non US
240Z 71-73 Auto (3.545) (R180)
260Z 74 MT (3.364) (R180)
260Z 74 Auto (3.545) (R180)
280Z 75-76 (3.545) (R200)
280Z 77-78 MT (3.545) (R200)
280Z 77-78 Auto (3.545) (R180)
280ZX 79 MT,4 Spd,2 Seater (3.364) (R180)
280ZX 79 MT,5 Spd,2 Seater (3.364) (R180)
280ZX 79 All With Automatic(3.545) (R180)
280ZX 79 MT,4 Spd,4 Seater (3.364) (R200)
280ZX 79 MT,5 Spd,4 Seater (3.7) (R200)
280ZX-GL 79 (3.7) (R200)
280ZX 80 MT,2 Seater (3.545) (R180)
280ZX 80 Automatic 2/4Seat (3.545) (R180)
280ZX 80 MT,4 Seater (3.9) (R200)
280ZX-GL 80 (3.9) (R200)
280ZX 81-83 Automatic all (3.545) (R180)
280ZX 81-83 Turbo - all (3.545) (R200)
280ZX 81-83 MT (3.9) (R200)
- - - - 300ZX's - - - - - -- -
300ZX 84-86 MT and A/T (3.7) (R200)
300ZX 84-86 Turbo MT and A/T (3.54) (R200)
300ZX 87-89 MT and A/T (3.9 ) (R200)
300ZX 87-89 Turbo MT and A/T (3.7 ) (R200)
Note Turbos:
#1) after 4/87 only-(3.7 Clutch Type LSD)
2) 88 All White SS used a 3.7 Viscous Coupling LSD)
3) LSD Unites Came With Finned Rear Covers
Additional Comments: a) Viscous Coupling LSD requires special splined half shafts - B) 84-87 R200's can be used in earlier cars, but require modifications they are not direct bolt in swapable to 240/260/280Z/280ZX's c) 84-89 R200's used a 12mm bolt in the ring gear - earlier R200 used a 10mm bolt in the ring gear, so you can not swap Gear Sets with the older R200's
Dragonfly
this might help some, there may be some variances in colors but this is what i have found so far. yellow 16 = 3.36, black 17 = 3.54, turquoise 18 = 3.70, white 19 = 3.90, red 20 = 4.11, purple 21 = 4.38. i have also heard of 4.4? ratios, maybe there is a cog for that one but it wouldn't coincide with the proportion of teeth:ratio. anyway, someone who is more familiar to chime in would be great, thats just what i've seen SO FAR.
