240 Z best ride height compromise for street and track
I think my compromise with the Eibach progressive rate springs and Tokiko shocks works well on the street and I sure have fun on the track. I'm about an inch lower than stock, which on a '78 was fairly high, but at least I have my fillings on these rough Denver streets...
Most road racers actually do not lower the car all that much, especially if your going to be on street tires, full on wide race tires can handle more spring, so if you wanted to lower it aggressively you could do so I suppose.
A guy I know who open road races, and road races, and instructs and yes AutoX too, lowered one car about half an inch and the other about an inch only.
Someone else on another board who also road races, likewise said lowering is overrated. I still like it, to some extent, just dont go nuts with it, thats one big plus of coil overs smile.gif
I'm at 6" at the front fender behind the wheel, about 6.75"ish at the rear fender in front of the wheel. You need a higher spring rate and better shocks to keep your car from bouncing around.
I'm not sure about the wieght of a chevy but with my sb ford I have 200lb infront and 250 rear. I'm out driving that rate now and will be going higher but not much. Um, I would guess 225--250 front and 300 rear for you? I think a chevy is heavier. ANyway, get stiffer springs and better shocks and upgrade when you need them. If you have coilovers buying diff. springs rates isn't that big a deal... $60 or so bucks a spring. And everyone's driving style is different. You need to find yours.
If you want a general setting, search the archives. THIS HAS BEEN DISCUSSED BEFORE.
Lates.
so what does that equate to under the car.. when i measured mine i wanted it 3" from the ground to the lower frame rail. which would be another 1/2" drop in front and 1 1/2" drop in back. and i felt i was being conservative, my father's porsche is 2 1/2" off the ground to lowest point but it scrpes going in and outta the drive, but speed bumps are ok if ya go slow.. ya don't have to diagnol them.
Cryus, have you replaced the old rubber bushings in the suspension yet? You might find that installing a fresh set of bushings (stock or poly.)is all thats needed .Install them before spending on new springs and shocks or at the same time you upgrade the rest of the suspension. Tom
