Aluminum Radiator options?
JDM RICE
What are you guys using as far as radiators for your RB? I'd like to keep both inlets on the left side to keep everything clean.
I was thinking about using an S13/S14 Radiator used for RB conversions. The dimensions are close, but I'm not 100% positive on a good fit.
Are there any other direct options that I can think of?
i dunno if this helps
clearance issues? well, some part of the front frame had to be cut, my hands cant reach the drain plug(can only drain if i remove radiator), everything fits with less than half inch clearance. apart from that, its fine. ran in sepang circuit trackday with ambient temp of 40 deg C, track temp much higher and the water temp is where it's supposed to be. so i bet it would be fine in the States where its much cooler...
I bought a rad off ebay from this outfit. also picked up an electric fan and nice aluminum shroud....and brackets. It was less than $500 including shipping. I'm VERY happy with the setup. Great quality, performance and value.
http://cgi.ebay.com/ebaymotors/19-X-24-DOUBLE-PASS-ALUMINUM-RACE-RADIATOR-LH_W0QQcmdZViewItemQQcategoryZ33602QQihZ020QQitemZ300176899553
http://cgi.ebay.com/ebaymotors/Aluminum-Radiator-Side-Mounting-Brackets-Weld-On_W0QQcmdZViewItemQQcategoryZ33602QQihZ020QQitemZ300177255367QQtcZphoto
