Guest rjfoo Posted January 15, 2008 Share Posted January 15, 2008 What modifications need to be done to the z in order to swap in a 280zx non turbo tranny? what parts will be required? Quote Link to comment Share on other sites More sharing options...
Shift Posted January 15, 2008 Share Posted January 15, 2008 starter motor clutch flywheel preasure plate bellhousing throwout bearing trans mount Quote Link to comment Share on other sites More sharing options...
JSM Posted January 15, 2008 Share Posted January 15, 2008 Clutch slaves (both firewall and on the Trans). Clutch line Pedals Quote Link to comment Share on other sites More sharing options...
JSM Posted January 15, 2008 Share Posted January 15, 2008 You should jump on this if you can. http://cgi.ebay.com/ebaymotors/240Z-Pedal-Assembly-Datsun_W0QQcmdZViewItemQQcategoryZ140725QQihZ019QQitemZ290196853698QQrdZ1QQsspagenameZWDVW Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted January 15, 2008 Share Posted January 15, 2008 so between shift and jsm is that it? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 16, 2008 Share Posted January 16, 2008 The whole pedal box unbolts from the firewall. To be complete you will also need a rubber shifter boot and the leather cover. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 18, 2008 Share Posted January 18, 2008 So is this a complete list and correct list? starter motor clutch flywheel preasure plate bellhousing throwout bearing trans mount Master and slave cylinders, tube pedals (brake and clutch) The only part I question is the starter. Is that because the OP asked about a 280ZX into a Z? Or is the starter different between auto and manual? I'll need to know for sure as I'm buying the swap parts from the same guy I'm buying the car from. I need to make sure I get everything that will be required. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 18, 2008 Share Posted January 18, 2008 You need more than just the pedals. You need to bolt them to the firewall. On a Z there is a box bolted into the firewall that mounts all the pedals and brake parts. So one way to do it is take everything apart and bolt in the pedal box from the manual trans car. It's a bit of work. Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted January 19, 2008 Share Posted January 19, 2008 The starter will swap over between auto and manual trannys. The pedal box for an automatic has the bolt holes for the clutch pedal and if you have the brake and clutch pedal you can use the pedal box from the auto. You'll need the pivot bolt. I'm not sure it is possible to swap it into the car without removing the pedal box. To remove and reinstall the pedal box, you must remove the dash and drop the steering column. Sounds like a lot of work but it really isn't that bad, a few hours. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 19, 2008 Share Posted January 19, 2008 Yeah I'm not worried about the dash removal. This also won't be my first auto to manual swap, just my first one in an S30. I am making sure that I have all (or most) of the parts needed when I get the car shipped, as I wouldn't want to have to source out the more difficult parts to find half way through the swap. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted January 21, 2008 Share Posted January 21, 2008 could one use s130 manual parts for a swap into an s30? Quote Link to comment Share on other sites More sharing options...
CArFAn Posted January 29, 2008 Share Posted January 29, 2008 Quick question do you absolutely have to pull the dash is there anyway around not doing it or is pulling it just a easy way. I really wouldn't want to pull the dash. Quote Link to comment Share on other sites More sharing options...
