I Need R200 Side Flange Axles
Corzette
Help...Im upgrading the R180 Diff in my Hakosuka to an R200. I have the R200 and the Victory50 Mustache bar made for the swap. The R200 didnt come with the flange axles in the diff so I will need to source those. I was thinking that all of you guys that did the CV conversion may still have some flanges laying around you dont need. I have some but in Texas storage. If anyone has a pair (left and Right) I would be glad to buy them from you. Id like to upgrade my R200 soon because its a 3.7 and the R180 is much higher I think. I only have a 4 speed in there and the 3.7 will help lots......please advise and thanks in advance....
Terry
Kameari Engine Works will sell you a brand new pair of R200 output shafts for not that much money. Would save some messing around sourcing used ones from outside Japan.......
HS30, thanks buddy, that is definately a great option. I also had sent an EMail to ZBarn. Thanks for looking out.
Terry
Terry,
I think this is what you need:
Click on pic for larger image.
They already have new nuts and bolts in them.
See if there is anything else you need: http://www.putfile.com/240ztt/images/143913
Let me know,
Joe, you are the man! Yes Sir, thats exactly what I need. PLease let me know how much you want for the left and right axle and I buy them asap.
Also I noticed you have a diff flange for the snout that bolts to the drive shaft flange. I have an R200 but havent checked to see if the spread is the same as the R180. I know there are two different snout flanges on the R200s. If the mounting holes on that flange you have is the same as the spread on the R180, I will take one from you too! Do you take PayPal or how would you like me to pay? This stuff would be going to zip 96387 and would need a customs form mailed USPS priority mail only. Shoot me the total price and Ill take em! Thanks Joe, saves me alot of time and I appreciate your help.
TErry
...Also I noticed you have a diff flange for the snout that bolts to the drive shaft flange. I have an R200 but havent checked to see if the spread is the same as the R180....
The R180 and the R220 input (front) flanges do not interchange because the pinion shaft diameters are different.
Yes you are correct. However the R200 snout flange has two different spreads on the bolt patern of which one is the same as the R180. Thats what I was needing. Otherwise I will need to find the snout flange that has the same bolt pattern spread. Ive had to change this more than once in the past and camnt remember what year they changed...
Terry
