Besides lsd200-300zxt parts worth anything?
madkaw
That's what i want to hear. I will buy it and part it out if I can break even or atleast get the diff cheap. Is the turbo engine worth anything, he says it has only 98k on it? I didn't see much happening on e-bay for 300zx parts.
If it is a 5spd - the transmission is worth some money, they are identical internally to an RB25 transmission.
Is this true?
The 87+(W) turbo cars had the 30a transmission, the pre 87 turbos had a T5.
So does this mean that a 30a is the RB25 trans which is also the Z32 trans as far as internals are concerned? What about the casing? I know the Z32 is shorter but what about the Z31 (30a version)?
Thanks,
Is this true?
Thanks,
The z31 30a is internally the same as the z32 30a and the 2wd pathfinder 30a. I think the z32 trans might be shorter, but I don't know for sure. I have no idea about being similar to the rb25 trans though.
If it is a turbo 5spd with LSD - it will have a 30A in it due to it being an 87-89. Yes - those transmissions are all the same model, with the Z31 unit being more desirable for S30 RB swaps because it still has a mechanical speedo drive. They all have slight differences, but the RB front housing fits them all.
