RedEvilrps13 Posted April 2, 2008 Share Posted April 2, 2008 Hey everyone, I have a quick question. I have the radiator and whatnot out of the car in preparation of doing the timing chain on my L28. What I am wondering is if I can just take out the charcoal canister and plug the vacuum lines, seeing as down the road i plan on taking out the EGR and lines purtaining to the EGR system. also, any other suggestions are welcome while i have the the front of the engine apart. Quote Link to comment Share on other sites More sharing options...
2savage Posted April 2, 2008 Share Posted April 2, 2008 If you take out the cannister you not only need to plug the vacuum lines but you need to plug the line that comes from the tank at the rear. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted April 2, 2008 Share Posted April 2, 2008 Yeah about that... Yes you can remove it, but you need to put a breather on the tank vent line, or the pressure in the tank can become a problem (or so I've read around here). Most people cut the vent line off near the tank, bend a U into it so gas doesn't spill out, then cap it with a filter. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted April 2, 2008 Share Posted April 2, 2008 Why would you want to do that? The canister costs you nothing in performance. All it does is save the gas that would otherwise evaporate into the air. At the price of fuel these days that could run into several thousands dollars a month. Quote Link to comment Share on other sites More sharing options...
RedEvilrps13 Posted April 2, 2008 Author Share Posted April 2, 2008 ah alright then nevermind. i was going to take it out just to clear up some more room up front, but nevermind. thank you all for the input! Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted April 5, 2008 Share Posted April 5, 2008 Hey everyone, I have a quick question. I have the radiator and whatnot out of the car in preparation of doing the timing chain on my L28. What I am wondering is if I can just take out the charcoal canister and plug the vacuum lines, seeing as down the road i plan on taking out the EGR and lines purtaining to the EGR system. also, any other suggestions are welcome while i have the the front of the engine apart. If you really want to polish up the engine bay you can replace the carbon canister with a stainless steel one and moved it somewhere more out of site. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted April 5, 2008 Share Posted April 5, 2008 I took mine off and ran the breather to just before my throttle body, doesnt waste fumes and looks cleaner. Quote Link to comment Share on other sites More sharing options...
datsun79z Posted April 6, 2008 Share Posted April 6, 2008 Hey everyone, I have a quick question. I have the radiator and whatnot out of the car in preparation of doing the timing chain on my L28. What I am wondering is if I can just take out the charcoal canister and plug the vacuum lines, seeing as down the road i plan on taking out the EGR and lines purtaining to the EGR system. also, any other suggestions are welcome while i have the the front of the engine apart. Here's another option; Remove the canister from it's currant location along with the mounting bracket. Relocate it above and in front of the passanger side front tire up under the fender. You will have to replace or extend by splicing the vacume hoses. I've done this and it helps clean up the engine bay. Road debris and water have not been of any issue. It makes things look a bit cleaner and you continue to help the enviroment a tad. Somewhere in one of the forums are pics of my engine compartment. Maybe Ron Tyler or Brapp could direct you to them. Hope this helps out. Mike HIntz Quote Link to comment Share on other sites More sharing options...
