Canadianz Posted April 29, 2008 Share Posted April 29, 2008 Hi guys, I have an RB25Det, which is almost done, my brother and I were wondering where the best place on the RB block is to get an accurate oil pressure reading as we want to hook up our autometer gauge. The stock oil pressure sensor is still hooked up, does it send information to the ECU or is it just for the dash ? If its just for the dash then problem solved. I was just leary of removing it if it actually sent data to the ecu on how the car runs. We thought about T-eeing off the oil input to the turbo but again wondered about an accurate signal due to the restrictor etc. Any input ? Thanks Chris and Rob Quote Link to comment Share on other sites More sharing options...
stony Posted April 29, 2008 Share Posted April 29, 2008 I would say replace the stock sender location. if it goes thru the ECU... it just goes thru it to maybe light a light or something nothing important if you are going to be running a gage anyways Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted April 29, 2008 Share Posted April 29, 2008 I would say replace the stock sender location. if it goes thru the ECU... it just goes thru it to maybe light a light or something nothing important if you are going to be running a gage anyways I 2nd that. I replaced me factory oil pressure unit with an autometer sending unit. I have never had any problems with it. I can get a 1/8 bspt to 1/8 npt adapter for you if you would like. They are close to 5 usd each. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted April 29, 2008 Share Posted April 29, 2008 I just drilled and tapped a hole into my oil filter adapter for the auto meter oil pressure sensor.... Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted April 30, 2008 Share Posted April 30, 2008 Sorry... I fixed the pic link above^ Quote Link to comment Share on other sites More sharing options...
synthtk Posted April 30, 2008 Share Posted April 30, 2008 I just put my Defi sender in the stock location, the stock one just goes to the cluster if I recall. Quote Link to comment Share on other sites More sharing options...
Canadianz Posted May 9, 2008 Author Share Posted May 9, 2008 Wow hey thanks guys, I appreciate the responses. I was just worried that for some weird reason I was going to mess up an ecu signal or something. The wiring is almost done now and I have the dash in, just had one of those hmmmmm moments. Quote Link to comment Share on other sites More sharing options...
