ls3 into a 240z same as ls1!
http://en.wikipedia.org/wiki/GM_LS_engine#LS3
"The block is an updated version of the LS2 casting featuring a larger bore of 4.06 in creating a displacement of 6.2 L (376 in³), 0.2 L larger than the LS2. It also features higher flowing cylinder heads sourced from the L92, a more aggressive camshaft with 0.551" lift, a revised valvetrain with 6 mm offset intake rocker arms, a high-flow intake manifold and 47 lb/hr fuel injectors from the LS7 engine."
More on Wikipedia, but it is sourced from LS2, not the LS7.
LS7 a different degree than the LS1? Doesn't sound right to me, more deck height maybe, but all SBCs are and ever will be 90 degree V8s.
yeah, I don't know where that came from, they are all the same, 5.3, 6.0, LS1, LS2, LS7, etc, they are just different composition, (i.e. iron or aluminum) and bore/stroke, etc but the blocks are externally more or less the same.
