DatsunD Posted May 15, 2008 Share Posted May 15, 2008 I have searched and tried again and again to fix this problem myself with no luck, so i passed it on to an auto electrician and $300 bucks three batteries and hours of my labor got me nowhere! -Here's the problem My battery is constantly going dead! Jump starting my car has become an everyday ordeal with my car. -Work done New battery and battery cables New voltage regulator New starter Tested alternator and it's ok but put new one in and it didn't change anything Tried to put in a acc relay from another car Mechanic said the problem was some wires behind the fuse pannel, solved the problem for a few weeks ALL HAS FAILED I let the engine idle and took the positive cable off the battery and THEN the alternator kicks in! I am out of patience ANY input would help! Thanks in advance Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted May 15, 2008 Share Posted May 15, 2008 Your car is a 74 260Z correct? With all the stuff you already replaced, I'd suggest taking a really good look at the wiring harness. These cars didn't have a great harness way back when and thirty years hasn't helped. Look for burned or frayed sections in the harness. Look at the harness in the engine compartment that hooks to the alternator. Look for signs that it has been tampered with or wasn't secure and got against the engine or touched something. Check all your grounds. Clean the surface they attach to. Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted May 15, 2008 Share Posted May 15, 2008 Have you checked the fusible links? Quote Link to comment Share on other sites More sharing options...
DatsunD Posted May 15, 2008 Author Share Posted May 15, 2008 I took off the whole dash at one time and the harness and connections look fine so i put it back together. The ONLY thing i can think of is my oil pump gasket went bad and my fan sprayed oil on the alternator side of my engine, maybe causing bad connections or wire? But i'f i had a bad wire or connection the alternator wouldn't kick in when i disconect the + side of the battery at idle. Quote Link to comment Share on other sites More sharing options...
DatsunD Posted May 15, 2008 Author Share Posted May 15, 2008 yes it's a 74 260z Quote Link to comment Share on other sites More sharing options...
Clifton Posted May 15, 2008 Share Posted May 15, 2008 I would put a later IR alt on it. Simple to hook up. Quote Link to comment Share on other sites More sharing options...
DatsunD Posted May 15, 2008 Author Share Posted May 15, 2008 I think i have one handy, i'll try that. I have a two wire plug going into my alt. I'll have to do some searching to figure out how to wire one up. Quote Link to comment Share on other sites More sharing options...
DatsunD Posted May 30, 2008 Author Share Posted May 30, 2008 I made the mistake of not puting in my radio fuse because i took it out of the car, found out it needed to be in for the ACC relay to function. I don't know how but i also found my flashers to be pulling alot of juice from the battery when not on, i found the relays and disconnected them untill i find good ones. Tested the car running and the alternator kicked in giving me 14v at idle. whew! Quote Link to comment Share on other sites More sharing options...
yessir Posted August 30, 2008 Share Posted August 30, 2008 HAVING SIMILAR PROBLEM???? WHERE IS acc relay LOCATED:confused: Quote Link to comment Share on other sites More sharing options...
DatsunD Posted August 30, 2008 Author Share Posted August 30, 2008 Under the passenger side dash is a cluster of relays, it's one of those. I'll send you a pic of the acc relay mabe tommorow. Quote Link to comment Share on other sites More sharing options...
yessir Posted August 31, 2008 Share Posted August 31, 2008 Thanx A Million Quote Link to comment Share on other sites More sharing options...
