Challenger Posted June 27, 2008 Share Posted June 27, 2008 Where and how to get them.... Quote Hi Guys, due to the amount of traffic this group buy is getting and requests from the organizer I am making a flat 15% off coupon for all Hybridz users to use at www.manufacturersdepot.com. Use hybridzpr15% for the Primer Model Use hybridzbl15% for the Black Model If you want to buy both Primer and Black please place the order with one coupon code. The administration of the site will then apply the discount to the rest of the order as well. Also note default shipping is FedEx Ground but there is a USPS 1st class shipping option for $4. Thank You, Matt Dawson Vortekz.com Materials- Vortekz Package- $20.99 shipped. Masking tape- Who doesnt have tape? String- Who doesnt have string? Alcohol- Rubbing/drinking most of us have one of them. Towel- Who doesnt have a towel? First off youll need to decide what area of the rear roof portion the vortex generators will be mounted on. Vortekz reccomends 100mm in front of the part of the roof where the air will seperate. I chose right above the rear hatch, I would use the top of the hatch as a line for mounting them. Second you need to clean the area youve decided on. Use conventional rubbing alcohol with a clean lint free rag. Third youll need to find the centerline on the car. I used the string and a little masking tape to center it on the car. To find the center I tied one end of the string to the center cowl vent in front of the window (13th from the outside one mine) I then pulled it along the roofline and centered the other end on the rear lock. From there place small pieces of masking tape below and above the area you will be working on. (double check alignment after this step) Fourth using the templates provided line them up along the center line. Next using the other set of templates, place them inside the above, and line up the top and bottom points at the 15 degrees (reccomended angle). You can then place the double sided adhesives inside each template trying to make it evenly spaced. Now pull off either side and move the template to the other side. Repeat it till you get the end with this pattern. *center* *15* *15* *10* *5* *0* Now take the right template and move it to the other side and repeat what you just did with this pattern. *0* *5* *10* *15* *15* *center* Moved to other side. All applied. From here you can take your vortekz and carefully place them on each of adhesive pieces making sure not to touch the adhesive with your fingers. This step is quite easy because they come shaped where they can only fit over the tape one way, the right way. Finished, looks like little shark fins! Overall these are really easy to put on, just take your time and be careful and theyll look great. it is also alot easier if you can stand in the trunk area. (no hatch glass ) Quote Link to comment Share on other sites More sharing options...
CalifaThugz Posted June 27, 2008 Share Posted June 27, 2008 Sweet. Made it look super simple. Quote Link to comment Share on other sites More sharing options...
BSD Posted June 29, 2008 Share Posted June 29, 2008 Great info and pics, makes it look too easy.. lol Quote Link to comment Share on other sites More sharing options...
Careless Posted June 29, 2008 Share Posted June 29, 2008 great writeup, thanks challenger. Quote Link to comment Share on other sites More sharing options...
torynich Posted July 1, 2008 Share Posted July 1, 2008 sticky? Quote Link to comment Share on other sites More sharing options...
Challenger Posted July 10, 2008 Author Share Posted July 10, 2008 Anybody else have pictures of their installs? I know 280zforce and proxlamus have installed these. There was also a lot of people in the group buy for these. Quote Link to comment Share on other sites More sharing options...
bschiltz Posted July 10, 2008 Share Posted July 10, 2008 http://forums.hybridz.org/showthread.php?t=122621 Quote Link to comment Share on other sites More sharing options...
TheMission Posted April 26, 2010 Share Posted April 26, 2010 Bump from forever ago... But, I just picked a set of this up and will be throwing them on soon... Love the way they look on the Z and probably couldn't hurt for functionality. Pics will come soon. Quote Link to comment Share on other sites More sharing options...
