Basic JZ series guide
RUSSJZ-ZED
from http://www.autospeed.com.au/cms/A_2750/article.html
One of the most potent engine designs in recent years has come from Toyota - the JZ-series in-line six. Released as successor to the smooth and faithful M-series six, the JZ engine has a DOHC 4-valve-per-cylinder head and comes in 2.5 and 3-litre capacities. You can also find versions with variable cam timing, a single turbocharger, parallel twin turbos, sequential twin turbos and direct injection. There's plenty to discover - so let's dive into the world of Toyota JZ engines.P> There’s plenty to discover – so let’s dive into the world of Toyota JZ engines.
Early 1JZ
The JZ engine range first appeared in 1990 with the naturally aspirated 1JZ-GE and its twin-turbo 1JZ-GTE cousin.
The 2.5-litre 1JZ uses oversquare bore dimensions (86 x 71.5mm) and, in naturally aspirated guise, a 10:1 compression ratio. With the aid of a DOHC, 24-valve head and a dual-stage intake manifold, the atmo 1JZ-GE produces 132kW at 6000 rpm and 235Nm at 4800 rpm. Not bad for a conventional 2.5-litre.
The atmo 1JZ-GE was fitted to the 1990 Japanese-spec Chaser, Cresta, Crown and Mark II. Like all JZ-series engines, the early 1JZ-GE is designed for longitudinal mounting and rear-wheel-drive. All of these models also came with a 4-speed automatic transmission as standard – there was no manual gearbox option.
Toyota also released a more desirable twin-turbo variant of the 1JZ during 1990.
The 1JZ-GTE twin-turbo was introduced to the Japanese market Supra GT (JZA70 series), Chaser, Cresta, and Mark II. The 1JZ-GTE employs twin CT12A turbochargers arranged in parallel and blowing through a front-mount air-to-air intercooler. With an 8.5:1 static compression ratio, the factory quoted output is 206kW at 6200 rpm and there’s 363Nm at 4800 rpm. These early 1JZ-GTEs are most commonly available with an auto transmission but a 5-speed manual version was available in the Supra GT.
In the following year (1991), the 1JZ-GTE was slotted into the all-new Soarer GT. Output remains at 206kW/363Nm and, again, most examples come tied to an auto trans. These 1JZ-GTE powered Soarers are quite common on the Australian market (as ‘grey’ imports).
The early generation 1JZ-GTEs are a great engine from a bang for buck point of view but be aware that the ceramic wheeled turbochargers are prone to failure. And they’re costly to fix.
Early 2JZ
The big capacity JZ engine – the 3-litre 2JZ – was introduced to the Japanese market in 1991. The naturally aspirated version was first seen in the Crown Royal, Crown Majesta and Aristo saloons while the twin-turbo variant appeared in the top-of-the-range Aristo.
With its square bore dimensions (86 x 86mm), the naturally aspirated 1991 2JZ-GE uses a 10:1 compression ratio and a dual-stage manifold to produce 169kW at 6000 rpm and 284Nm at 4800 rpm. It mightn’t have forced induction but this is a very strong engine for its capacity.
Curiously, the 2JZ-GE was spread into the Chaser, Cresta and Mark II range during 1992 but the quoted outputs are down 7kW and 4Nm – we can only assume there are differences in the exhaust, air intake and perhaps ECU tune. These early atmo 2JZs are typically fitted with an auto transmission.
The last car to receive the 2JZ-GE was the Toyota Soarer coupe of 1994. In Soarer spec, the 2JZ generates a full 169kW/284Nm (the same as the Crown range and Aristo).
And, despite popular opinion, the awesome twin-turbo version of the 2JZ was not first released in the Supra.
The first application of the twin-turbo 2JZ-GTE was in the nose of the top-line 1991 Aristo. And, as you’ve probably heard, this is an absolute humdinger of an engine. With a static compression ratio of 8.5:1 and a sophisticated sequential twin-turbo arrangement (using a pair of CT12B turbochargers), you’re looking at a conservatively claimed 206kW at 5600 rpm. Peak torque is a huge 432Nm at 3600 rpm with 380Nm from just 1300 rpm... In Aristo spec, the 2JZ-GTE comes fitted with a 4-speed automatic trans.
When the same engine was later installed to the JZA80-series Supra (from 1993), buyers had the option of a 6-speed manual. Engine output is identical in the Aristo and Supra.
VVT-i Update
Through the mid-to-late ‘90s, the JZ-series engine was treated to variable inlet cam timing (which Toyota calls VVT-i).
From 1996, the entry-level 2.5-litre 1JZ-GE received VVT-i as well as a compression ratio increase of 0.5:1. These changes helped achieve a very creditable 147kW and 255Nm (up 15kW and 20Nm from earlier models). These VVT-i 1JZ-GEs come fitted to the 1996 Chaser, Cresta, Crown and Mark II; they’re all autos.
Interestingly, the turbocharged 1JZ came in for a lot more than just VVT-i and a small compression ratio increase.
For the 1996 model year, the 1JZ-GTE lost its parallel twin-turbo system in favour of a large capacity single turbocharger. With a big CT20 turbocharger blowing through an air-to-air intercooler, the VVT-i 1JZ-GTE produces 206kW (as before) but with a massively improved 378Nm at 2400 rpm. It’s easy to dismiss the switch from twin turbos to a single turbo as a downgrade but back-to-back road tests show this to be a far better engine than previously.
The 1JZ VVT-i single turbo came fitted to the updated Soarer, Chaser, Cresta and Mark II of ’96. The same engine was then applied to the 1999 Crown and Crown Estate, 2001 Verossa and 2002 Mark II Wagon Blit. Most examples are fitted with an automatic transmission but there are manual versions to be found. These engines are quite scarce at the import wreckers but they’re an excellent package.
The big-banger 2JZ 3-litre also benefited from the introduction of VVT-i.
In 1995, the Crown and Crown Majesta received variable inlet cam timing and, like the atmo 1JZ, a slightly higher compression ratio (up to 10.5:1). This went toward achieving 162kW at 5600 rpm and 294Nm at 4000 rpm. The same engine was then introduced to the Chaser, Cresta and Mark II in 1996 and, in 1997, a higher tuned version (producing 169kW at 6000 rpm) made its way into the updated Soarer 3.0GT.
Nineteen ninety-seven also saw the release of the all-new Aristo (which is recognised in Australia as the Lexus GS300). The new Aristo boasts the same 169kW output as the updated 2JZ Soarer and comes with tubular headers and electronic throttle control. Don’t underrate it – this is a very potent engine considering the absence of forced induction.
Also making news in ’97 was the VVT-i upgrade of the already stunning 2JZ-GTE sequential twin-turbo. With the introduction of variable inlet cam timing and electronic throttle control, the 2JZ-GTE’s power output remained at a conservatively quoted 206kW but torque increased to 451Nm at 3600 rpm – almost 100Nm more than the ‘awesome’ Nissan R32 Skyline GT-R... This benchmark engine was available in the ’97 Aristo and ’98 Supra. It was discontinued in around 2001.
Of course, this engine is always in huge demand in performance circles and you’ll typically pay top dollar for one.
There were small ongoing changes to the VVT-i 2JZ for the next couple of years and, most importantly, Toyota released a 158kW/294Nm version in the Progres sedan and a 162kW/294Nm version in the Altezza wagon.
Direct Injection FSEs
In around 2000, Toyota introduced what are probably the least recognised members of the JZ engine family – the FSE direct injection variants. These FSE 1JZ and 2JZ engines are aimed at achieving minimal emissions and fuel consumption together with no loss of performance.
The 2.5-litre 1JZ-FSE employs the same block as the conventional 1JZ-GE – everything up top, however, is unique. The ‘D4’ FSE employs a relatively narrow angle cylinder head with swirl control valves that serve to improve combustion efficiency. This is necessary to run at extremely lean air-fuel ratios - around 20 to 40:1 at certain engine load and revs. Not surprisingly, fuel consumption is reduced by around 20 percent (when tested in the Japanese 10/15 urban mode). Interestingly, normal unleaded fuel is enough to cope with the FSE’s 11:1 compression ratio.
The direct injection version of the 1JZ generates 147kW and 250Nm – virtually the same as the conventional VVT-i 1JZ-GE. This highly efficient engine is fitted to the 2000 Mark II, 2001 Brevis, Progres, Verossa, Crown and Crown Estate. All are fitted with an automatic transmission.
The 3-litre 2JZ-FSE uses the same direct injection principle as the smaller 1JZ version but runs an even higher 11.3:1 compression ratio. This engine matches the conventional VVT-i 2JZ-GE with 162kW and 294Nm. The 2JZ-FSE is fitted to certain 1999 Crown models and the 2001 Brevis and Progres. Again, all use automatic transmissions.
These FSE engines are certainly very interesting from a technical perspective but, at the time of writing, we have not seen one imported to Australia. On the other hand, the turbocharged 1JZ and 2JZs can be found in generous numbers – it’s never been cheaper and easier to buy an engine that’ll run with the giants of the performance world.
Gearbox comparisons.
W58
  • First Gear: 3.285:1
  • Second Gear: 1.894:1
  • Third Gear: 1.275:1
  • Fourth Gear: 1.00:1
  • Fifth Gear: 0.783:1
  • Reverse: -3.768:1
  • oil capacity 2.6 litres
  • R154
This is a robust 5-speed transmission found in the MKIII Supra Turbo, Toyota Soarer (turbo) up to 2001.
Toyota chaser JZX90, JZX100, JZX110
Ratios:
First Gear: 3.250:1
Second Gear: 1.955:1
Third Gear: 1.310:1
Fourth Gear: 1.00:1
Fifth Gear: 0.753:1
Gearbox Lubricant Capacity - 3 Litres
Oil specifications 80W-90 GL4 or 5 Gear Oil
Soarer tt final drive 4.083 to 1
Mk3 supra(r154) final drive 3.7 to 1
V160
Ratios:
First Gear: 3.830:1
Second Gear: 2.360:1
Third Gear: 1.680:1
Fourth Gear: 1.310:1
Fifth Gear: 1:1
Sixth Gear: 0.790:1
Applications: Mk 4 Supra TT
Oil capacity,1.8 litres
final drive 3.266 to 1(Japan market)
1993-May 1996 Supra turbo
V161
Ratios:
First Gear: 3.724:1
Second Gear: 2.246:1
Third Gear: 1.541:1
Fourth Gear: 1.205:1
Fifth Gear: 1:1
Sixth Gear: 0.818:1
Fluid capacity 1.8 litres
Applications:
June 1996-July 2002(JDM)
Supra turbo
final drive 3.266 to 1 TT (Japan market)
( 3.769 to 1 - late model NA 6 speed)
  • 2 months later...
Well done, Russ. THANKS!
Not claiming the kudos for this, engine information shamelessly lifted from local magazine site, http://www.autospeed.com.au/cms/A_2750/article.html
(I notice someone else thought it was good as well - and loaded most of it onto wikipedia)
gearbox info from
http://www.toymods.net/forums/ -lots of good toyota petrol head transplant stuff here.
Figured it was good information that should be readily accessable here.
Autospeed also has these items of interest.
import motors.
http://www.autospeed.com.au/cms/A_110616/article.html
7mgte.
http://www.autospeed.com.au/cms/A_110590/article.html
injector swaps.
http://www.autospeed.com.au/cms/A_110359/article.html
intercooler maths.
http://www.autospeed.com.au/cms/A_109789/article.html
budget intercoolers.
http://www.autospeed.com.au/cms/A_109459/article.html
superchargers. http://www.autospeed.com.au/cms/A_109125/article.html
Or just hit their index and chances are what you want is in there.
http://www.autospeed.com.au/S_3/cms/section.html
You seem to speak of the vvti upgrade on the 1JZ-GTE rather positively. I have heard people on other forums say that this is an engine to avoid for tuners.
As a Toyota newb, I haven’t a clue but I was hoping you could touch on the subject of modifying vvti engines?
I went for the vvt version for a couple of reasons,
1) it is a newer, later development of the engine series
2)It makes more power than earlier version
3) max torque 378Nm is reached at 2400rpm(4800rpm on1J non vvt,-the 2JZGTE Vvti is 451 Nm at 3600rpm-Torque =fun)
4)only one turbo to go bad.
As a street/highway cruiser with engine totally unmolested, quiet,docile,smooth runner,untill it gets to over 2000rpm, then it snarls and turns into Frankenstein,that low down torque is brilliant!-there is no need to work it,
Performance parts are harder to find but readily available from Japan,(try it unmolested before you start spending money) lots of talk about how the rods are weaker than earlier non vvt's and how they won't stand up to 1000HP, -a quick reality check will tell you a 30+ year old Datsun won't either.
Depends on what you want ,
a trouble free street car with scary perfomance,more grunt than a hippo with haemoroids,(be very carefull on a wet road, and by wet ,I mean anything more than light mist!)
or a zillion dollar track days only racer.
  • 11 months later...
  • 1 month later...
I would add that, since I am looking at doing an inline 6 turbo swap, I am doing a lot of research on the Toy L6's. The 1JZ is short on piston/rod options. Most of the options are either quite expensive or imported from japan; which is also quite expensive. Rods particularly.
EDIT: I found Spool rods for $695, but I have not heard much of them. One fellow was after them on SupraMania after his ~750+ whp 1JZ finally bent the rods.
For additional info;
http://www.supramania.com/forums/showthread.php?t=29117
Summary:
-2JZ cams can be modified by a machinist to fit; some people sell cams, however. Crower makes a set that got three digit gains at redline and steep two digit gains at peak. :shock: (search for the group buy on supramania)
-Pistons are the same as 2JZGTE; including wrist pins and rings
-Main and rod bearings are the same
-Timing belt from an Isuzu fits. :mrgreen:
-Valvetrain is swappable
-Water pump is an upgrade
-Some guys retrofit 2JZGTE ECU's
-I've seen guys flowbench a 1JZ with 2JZ valves for substantial gains on a flowbench
-Alternator and Power Steering
-Head Gasket
-Head Studs/Bolts
-Rod Bolts
I would add that the above post by Wizard is for the 1JZ.
Still no Sticky??
Gah! Sorry. :icon56: I guess I implied that by what the title of the linked thread is, but I shoulda have been more obvious about it. Can a mod edit my post for me to make that explicit? Maybe delete this post on top of it to clean it up? If it gets stickied...
