ECU swap
luvmy280zxt
Any of the turbo 5 speed ECU's will work in your 81. The main difference between the manual and 5 speed that I noticed was the rate the RPM's fall off between shifts. The 5 speed ECU will let the RPM's fall off slower, making for smoother shifts while tooling around town.
I was told that the auto ecu in a five speed have a few differnt parameters. For instance at a stop light the rpm's stay up, at a idle, a little more than the manual because the auto ecu is designed to always have some kind of load on it while it is in drive. I think that may be the most noticable though. I did this w/ one of my zxt's, also seemed to run a little rich too.
