widest rear tires
There is a way to figure this. Measure the distance from the tire to the inside lip of the fender well on the outside and from the tire to the nearest non-rotating component of the car on the inside.
Be sure and think about suspension travel, etc. and what the tire could get close to when cornering or hitting a bump.
The shorter of the two distances, times 2, will give you the absolute maximum increase in tire size over what is on the car. Then you will have to see what tire sizes approach that dimension. Also remember that a change in profile will affect sizing, that a change in size will affect the location of the widest point of the tire.
Best bet would be to find a shop willling to mount a tire for you to check it before buying. If it looks reasonable most of them should be willing.
Tire sizing is not exact. There are variations between brands and even within brands. All 245/50-16 tires are not the same.
After that is all said and done you then need to look at your wheel and ensure it's rated for a tire that size. If you get on Tire Rack they'll show recommended wheel sizes for different tire sizes.
