Removing Tie Rod Ends/Front Suspension Questions
How do I do this? I need to disconnect the tie rod from the spindle so I can drop the strut out for new shocks and springs. The fsm shows a little tool that looks like a valve spring compressor. Is there any other way to get it off without the tool. Can I just pound it out from the top?
Thanks, archives didnt really show anything, just how to remove the inner tie rods.
Take the two bolts out of the bottom of the strut and you can pull it right off of the steer knuckle, no fussing with the tie rods necessary.
If you were going to remove them and replace or something like that and needed to get them off, then you would not want to pound from the top. You'll mushroom the threads and then you've got real problems. You can use a pickle fork but it will tear the boots, or the tool that you described, either of which you can buy at auto parts stores or online. A pickle fork on an air hammer works great. I've never had much luck at this but some guys will whale on the side of the piece, in this case the steer knuckle right where the tapered section of the tie rod goes through with a BFH. If you do this right the vibration will pop the tie rod loose.
OK thanks, I actually just got back from Shucks and got a pickle fork for $10.85, pulled it right off.
Im going to go look now for the two bolts you mentioned. But I will be replacing the tie rod ends.
-- Were the bolts you were referring to the ones holding on the bar that goes diagonally backwards to a mounting point on the frame? (dont know what its called :( ) I did remove those but it wasnt enough clearance to get the top of the strut out.
An old mechanic once told me, loose the nut, and hammer the metal piece (not the tie-rod) same goes for Ball joint. Your paint might take a hit, but it will work and you can reuse them. Don't put grease either in them, they will start turning and you are in a new set of problem
Dayz
Got another question, Ive got all the struts out where I can work on them. Looking at the base where the knuckle attaches to the control arm it looks like there is a joint there. How do I know if this needs replacing or if it does is it a replaceable part?
Edit- http://www.thezstore.com/page/TZS/PROD/SSSC01A02/23-4301
Is that the ball joint?
Well I have new tie rod ends for both sides, and a full bushing kit, along with shocks and springs.
I used the pickle fork because Im replacing them (dont need to save grease boots, their gone anyways). If I need to remove them again without replacing them Ill get the other tool.
As for who to get the ball joints from, I did some searching at it seems that everyone likes courtesy nissan parts rather than something from shucks (ordered from parts america). Are the McQuay-Norris ball joints any good?
Little update, got the front suspension torn apart. Ball joints are a MUST! They are completely shot.
Now on to the back Im trying to get the control arms off from the inner connection. I took off the bolts on each end, now all I need to do is take of the 4 bolts holding on the hangers? I have my chiltons out but its of no help...
The "hangers" are the pieces directly below the white bushings in this picture.
Once I remove those will it drop down and slide forward or will I need to take out the crossmember at the front mounting point?
Just to let you all know Id be out there just tearing it apart if I didnt have 12 stiches in my finger, Im having to limit my time working on it and need to know exactly what I need to do before I start removing stuff.
Appreciate the help, thanks!
