1rad280 Posted September 17, 2008 Share Posted September 17, 2008 I check all of my bulb on my 280z and found that none of my turn signals worked no blinking noise nothing, so I started with new bulb and nothing changed, I replaced the flasher relay nothing changed. What should I check now? Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 17, 2008 Share Posted September 17, 2008 By flasher relay do you mean the flasher canister under the drivers side dash? I also have this issue, but the lights work, but no flash. Im guessing its the canister. Quote Link to comment Share on other sites More sharing options...
1rad280 Posted September 17, 2008 Author Share Posted September 17, 2008 yes the canister. Does you reverse lights work? Quote Link to comment Share on other sites More sharing options...
1rad280 Posted September 17, 2008 Author Share Posted September 17, 2008 Have you replaces the canister? Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 17, 2008 Share Posted September 17, 2008 yes the canister. Does you reverse lights work? Yes but no brake lights. Just running lights, brake pedal does nothing, Im hoping its just the switch. Quote Link to comment Share on other sites More sharing options...
woldson Posted September 17, 2008 Share Posted September 17, 2008 Oddly it seems you are talking to thy self,,,, Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 17, 2008 Share Posted September 17, 2008 Fixed it.. maybe I did ramble a little to myself. Quote Link to comment Share on other sites More sharing options...
gwnwar Posted September 17, 2008 Share Posted September 17, 2008 IRad280 did you check the fuse?? Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted September 17, 2008 Share Posted September 17, 2008 On the brake lights, the switch pushes against a little plastic piece that is inserted in a hole in the brake pedal arm. Over time little plastic piece turns to dust and falls out. Switch has nnothing to push against and pokes through hole. Easy to check, just stick your head under there and look. Appropretly sized body plug from any parts house makes good replacment Quote Link to comment Share on other sites More sharing options...
1rad280 Posted September 18, 2008 Author Share Posted September 18, 2008 My turn signals are inop not my brake lights or my reverse lights. Quote Link to comment Share on other sites More sharing options...
1rad280 Posted September 23, 2008 Author Share Posted September 23, 2008 After looking at my wires I wiggled the wire going into the turn switch and the right side started working but the left didnt. Quote Link to comment Share on other sites More sharing options...
