2eighTZ4me Posted September 17, 2008 Share Posted September 17, 2008 I have a Racer Brown cam (springs, retainers, etc.) that came off a running car. Lobes look ok. I have a set of factory rockers that were reconditioned by Delta Cams. Most of what I have read about seasoning a cam has to do with a new cam or a regrind - not one that's been run in another head. What steps should I follow to make sure this guy gets broken in properly? I am going to use Valvoline VR1 oil with ZDDP for the initial run for sure. Do I need to run it at 2K RPM's for 30 min. as one normally does for a new cam? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 17, 2008 Share Posted September 17, 2008 That is supposed to work harden a cam. It's not normally done on an L series cam, it's more of a V8 thing, and it wouldn't be necessary if the cam was already used. Quote Link to comment Share on other sites More sharing options...
woldson Posted September 18, 2008 Share Posted September 18, 2008 Question: If you get a cam, used, and the rocker are yours, what then? (and why, if I may be so bold to ask.) Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 18, 2008 Share Posted September 18, 2008 That one has been an area of contention for a long time. Some people say you need new rockers. Some say you can resurface the rockers. Some say you can run the old rockers. It's a long standing debate. My take is that you can use the old rockers. My rockers are on their 3rd camshaft, no problems. Quote Link to comment Share on other sites More sharing options...
Careless Posted September 18, 2008 Share Posted September 18, 2008 It wouldn't hurt to just lightly sand the rocker contact face with some 1000 to get it back to a shine. Some also use the older Rotella T oil that is still available if you look hard. It contains a lot of lead too apparently, and is a common SBC break in oil Quote Link to comment Share on other sites More sharing options...
